Mate, I hope you do get something extra for having a Nismo ECU :blink: . You'd have to be annoyed at paying money for nothing more than you could get by cutting a wire.
Surely Nismo don't just disable that input and sell it for $800 or whatever?? That would be a huge scam if that was the case lol.
I can tell you this....If I put the Standard ECU or Impul on my car with the turbo I have on it its a Fat Black laggy POS.....4,800rpm before boost starts to climb. With the Nismo it was full boost by about 4,200rpm before the tune.....after the tune full boost by 3,200RPM and Cihan pulled some timing out because it was too reactive.
Kickdown has also been played with!
oh and I can do more than 171.5km/h. :P
I'll lay London to a brick that if a Nismo came up on IM you guy's would be all over it!.....it's the best plug and play mod you can get!...snipping the wire just let's you do burnout's!....well maybe not for Aaron :P
Edited by Jetwreck
i dont think it would still let anyone with a highflow do burnouts(stock ecu that is). without a high stall its only a little bit better...
i think my next challenge is to disable the attessa with a switch, and still be able to keep ABS.. the plug under the dash puts the 4WD light on, but i think it reacts the same and pushing the "synchro" switch.
which leads me to believe there is clearly more to the ECU than a throttle opening..
One of my test launches yesterday (with brake switch disconnected) caused the 4WD light to come on :whistling:, but this mod doesn't mean instant burnouts.
Our ECU's are very much like women; I don't think any of us guys really understand how they work, but we know what we'd like them to do better, LOL
LOL
yeh theres a plug attached to the OBD port, this is 'meant' to disable the 4WD. unplugging it certainly turns the 4WD light on, but it felt more so of 50/50 distro as i couldnt spin the wheels up at all and it was wet. but it definitely pulled as if the roads were dry..
i want more of a 0/100 lol
LOL
why don't you try one of these then....use to have one on our old R32 GTR....worked very well.
http://www.ebay.com....=item19c5b4b24f
sent off a question asking them if it works for the M35.
Would like to see what our cars would run on the Dyno just in RWD!!!
Edited by Jetwreck
it would be something I could consider..
but i wouldnt know where to start with wiring it in succesfully I cant seem to find a diagram for our attessa wiring system..
but isnt that more for being able to split torque to the front when you want instead of when needed.
it says that normal mode is just 'stock'
FFS!....isn't that what you want.....man your sizzled :P
It does for me. :)
Haha, yeah I know for a few of you guys it does. I was meaning for the majority of us with minimal mods, but you knew that & were just showing off ! LOL
I enquired about this one a while ago & it's never been used in a M35 yet. I can't see why it wouldn't work with our cars, but.....
OK, found the message:
"As far as I know no one is using one on an M35. If you want to take some photos of the G-sensors and connector under the center console I can certainly tell you if it is likely to work and I would be willing to refund your unit if it turned out not to be suitable after trying.
Regards Justin"
I really wanted more front wheel torque for those wet days when you want to get where you're going quicker & with less RWD "fun".:happy:
Edited by Commsman
Regards Justin"
dont you have a synchro button?
Yes I do :yes: But so what?
You're going to tell me that using syncro will engage proper 4WD, right?... Well when I do that it feels like I'm driving a 4WD with the front hubs locked. You know, harder to turn in tight spaces etc. What I want is partial or progressive front wheel torque, without the "lock up" feel.:huh:
LOL
did you unplug it and pump the break pedal 5 times?
i liked it, mine doesnt feel to jittery
yeh it doesnt do anything.. but i figured out full time RWD read the attesa thread.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
