  • Replies 192
lol, you lifted the rear of the bonnet yet you left the rear bonnet seal on the firewall. You must drink more than me :P
plan was to leave it in then hit the track
if its still over heating then rip it out mid track day then see how it goes
as for drinking more... yes.... yes i do!
in other news ive seen a heap of alloy ones and they all stop at the grill( they dont extent to the bonnet)? any reason for this?
on the gibson car there plate is flush with the bonnet, thus direction all the air below the bonnet to the rad?, this was the main reason why i went flush with the bonnet
need more bonnet lift beeratch.. i had mine lifted 25mm. cant say i noticed any great difference... but after pulling the motor and seeing all the shit and corruption in the cooling system... i think i know why. made a great demister on cold mornings though.
wheels look tough on the mrs' car.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
