they aren't too bad in person, the polished spokes go well with the chrome accents on the car. definitely can do better though.. maybe just get some 22's like this:
http://www.supraforums.com.au/forum/members-rides/58430-2002-nm35-autech-axis-stagea.html
http://www.supraforu...xis-stagea.html
I can't stand stupidly large wheels normally; but that car makes me a little tingly in my wingly.:wub:
Don't worry too much what people think; everyone's different, but some higher profile rubber will sort out the proportioning issue, and most likely improve the ride.
Edited by Daleo
Massive aside, I think someones dyno was being a bit generous if they made 180rwkw with only a fmic :whistling:
My ideal wheels would be 19" CE28N's :yes:
DROOOOOOOOOOOOOOOOOOOOOLS...
Im going to stick with CE28 copies as my bank balance doesn't go far enough for the real deal!
I'll be joing the wheels club tomorrow. Picking up 4 big packages that have made their way from Japan! Won't have time to fit them up, so it'll have to wait a few weeks >_<black_lrg.jpg
19's SSR type F
In black.... I think that's the road I will go down. Solid black FTW!
I'll be joing the wheels club tomorrow. Picking up 4 big packages that have made their way from Japan! Won't have time to fit them up, so it'll have to wait a few weeks pinch.gifblack_lrg.jpg
19's SSR type F
Very nice Alex!
Can't wait to see these on!
19's SSR type F
What is the width/offset you went? :)
19x8.5 +22 all round.
For those playing at home, its exactly the same fitment as what BBenny has with His Enkei GTC01's. There are lots of photos of that round for refrence.
Picked em up, can't wait to have them on!
JDM Concept. Under 3k, pick up. Prices are on the website- good pricing (good service too) as far as I could work out, but there will always be someones second cousins sisters brother that got them cheaper in timbuctu, if you get my drift...
With tyres?
That's a good price then. I thought you might have got them ex Japan. Freight for a set of 19" wheels is over 1k alone! That's partly why I went with 18" as the freight is less than half of 19".
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
