anyone got these on there car? or similar?
http://www.ebay.com....0#ht_1263wt_984
http://www.ebay.com....c#ht_1075wt_907
just want some feedback......good? bad? noisy? hard to setup?
Apparently these particular ones are not renowned for their sturdy construction.
Check these;
http://www.ebay.com.au/itm/Nissan-STAGEA-M35-SKYLINE-V35-350Z-REAR-TOE-ARMS-/130554820791?pt=AU_Car_Parts_Accessories&hash=item1e65ac78b7
Doesn't appear to have any Front Arms ATM, but he does get them.
I've dealt personally with this trader; (Bought my BC BR's from him) great guy, answered heaps of questions, couldn't do enough to help, and then followed up several weeks later to ensure I was happy. Nuff said.:thumbsup:
what about K sport
BE-0019 Rear Camber Arms (Nissan- S14 . S15 . R33 . C34 . C35 . GTR . Skyline) Pillow Ball
BE-0026 Pillow Ball Rear Traction Rod (Nissan- S14 . S15 . C34 . C35 . R33) Pillow Ball
BE-0029 Rear Traction Rod (Nissan- S13 . S14 . S15 . 300ZX . Z32 . R32 . R33 . 180SX . A31 . C33 . C34 . C35) Pillow Ball
BE-0049 Tie Rod End (Nissan- S13 . S14 . S15 . 300ZX . Z32 . R32 . R33 . 180SX . A31 . C33 . C34 . C35 .) Aluminum / Pillow Ball
BE-0057 Tension Rod (Nissan- S14 . S15 . C34 . C35 . R33 . Z34) Aluminum 6061 / Pillow Ball
I thought those were the ones you had Ryan.
Y u no fit them?:nyaanyaa:
Because I'm a slack bitch!
Nah, I want to get them fitted right before I get a wheel alignment so they can be properly adjusted. And if I wait until I get the BCs, which looks like it will be quite soon because I'm getting really sick of it wallowing, I can get it all aligned in one hit.
Lol all good I know.
Turns in really well now with the strut brace and sway bars, hopefully the shocks fix up the ride. Looking forward to getting the toe arms in there, as it looks like it needs a bit of a camber adjustment on the rear.
Hang on, are you trying to adjust the camber with toe arms?
Edited by slippylotion
what about K sport
Not sure if C35 is the same as M35. Highly doubt it...
not even remotely the same
the S and C and R chassis have a completely different suspension setup to V and M chassis.
i was just thinking they cocked up the letter HAHA
well the kit is apparently the same as the R35 apart from one rear rod is different
anyone thinking of getting the castor/radius arm bushes on their M35 should get it for sure. best drive ive had of my car in a long time. it feels so good on the road now. no creaking and no clunking!
I know it was probably discussed 6 pages ago in an unrelated thread, but where from & how much?
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
