  • Replies 136
wakefield looks like a rippa of a circuit!
i will have to make the trip accross the border and russle some NSW feathers in the not to distant future i think... :P
Ask snowcone and scotsman when they're coming up next and tag along with them - they plan it all and you just come and make up numbers, and driiiiink :yucky:
i saw that! thought it was ben playing in the dirt :P
thanks for a great day guys
the drivers were all courteous out on the track and let me through with a minimum of fuss. the weather was great. track was great. great day :P
the fridge managed a 1:07.6. go the sr20 ;)
Bloody awesome time and very noice car!! I was the Blue S13 running in your group but only managed a few laps all day due to suspension / brake issues.
Could i pester you for a 'brief' on what you have done to the car? I punched out a 1:10 but has a lot more in it once 'issues' are sorted. i meant to come sticky beak at your car but was too busy trying to fix / diagnose my own problems!! I am always trying to get ideas on setups, more so engine / turbo choices. But if you feel like giving me a full run down i would love it!!! ahahahaha
You can post or PM me if you like :) :)
Or if you like to keep it a secret, that is A ok with me!
Cheers,
Ando
hey hey, i think your onto something there!!!
only i dont drink... :P
safety in numbers i say! it will be a victorian invasion! :P
Yeah they've had 2 of them before, send them a PM and see when they're planning the next one
Dont worry, they'll drink enough to cover your share. Chris managed to (all at the same time) park the car, drink a beer with one hand, then, using his other hand open a beer for me. And the car was parked perfectly. Its 2nd nature hahaha
You can post or PM me if you like :D:)
Cheers,
Ando
yeah, no probs ando. comeand have a stcky beak next time
I'll be out and about a few more times this year
on a down side tho, we did manage to end up with a cracked exhust manifold from the day :P
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
