my sets of wheels
1st- AVS model 5 17x8/9 cant remember offsets federal 595 SS tires
2nd- Panasport G7 17/8.5/9.5 cant remember offsets stretch wanli tires
3rd- Enkie ?? pair 16x7 yokohama DNA GP tires
4th- TE37's 17x9 +20 Dunlop 03's
5th- Enkie NT03 17x8/9 +32/+15
6th- Work Emotion CR Kai 16x8 +30ish random tyres
7th- TE37's 17x9 +20 RE55's
8th- Weds Sports SA70's 18x10 +18 Bridgestone RE050A RFT fronts Michelin
Pilotsport RFT rears 255/35/18 all round
9th- Work Equips 18x10/12 -16/-9 something Bridgestone RE11 245/35/18 fronts no
rears yet..
loved every set :)
Axis Hiro:
You won't get as much dish on a GTS-t, but they designed the Hiros to get deep dish so even with a relatively weak offset you should have some.
Lenso D1R (aka Project-D):
Yes, the Lenso D1R won "BEST WHEELS" Award at the 10th Anniversary R34 GT-R Celebration last year.
For thinner spokes > Rays RE30 with Titanium face & Satin Silver dish.
That fitment is awesome, does it scrub it's balls off at the front?
Respect for having the knackers to go with some decent fitment and not make your 33 look like some limp wristed, sunken wheeled, wally-mobile.
Watch out for the fun police too! They'll be along soon to tell you it's impractical/your tyres are too thin for a 10 inch wide rim.
thats ur opinion, the car will prob never see more than 235's on these rim for drifting, which is what the car is built for..what part of it makes it impractical??? if i was track racing id have different size rims and tyres...whats the problem,
anyway the car looks great and the rim/tyres fill out the guards perfectly, like i said there's a bit more camber in the back so the rim just barely sticks out compared to the pic..and there is not rubbing on the front either :laugh:
I have a feeling the comment was a gee up, hence why it was a direct copy of my fun police warning.
235's on a 10" arent the end of the world, for the most part 235's have SFA stretch on a 9" so on a 10 should look toasty.
Legalities aside that is.
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
