This thread will contain all my adventures in the setting up of my on the move entertainment solution for my M35 Stagea.
The beginning.
I tooled around the forum for ages, looking at Stageas and V35's. I met with Andy (cheers again) and saw his setup. I swapped emails with Chris and Chook. Then developed a plan.
Bought the TV tuner form Chook, the lead/adapter from Chris, steering wheel controls from Chris and also got a recommendation for an awesome local installer. I'm reasonably handy when it comes to mucking about with basic ICE setups but I'll need an installer for this as I want some custom made bits.
I liked the ipod setups I'd seen but also fancied a carputer. The I decided I could have both and swapped the Nokia for an iPhone.
So the setup will go like this:
OEM stereo for CD's and radio - like the idea of OEM and steering wheel controls
Working TV tuner with AV inputs which will also feed the iphone and reversing camera to the OEM screen.
Iphone will provide phone, music, videos and GPS and also email and web on the move, all visible on the OEM screen.
I am having a custom dock solution made which will replace the ashtray and having the TV tuner remote integrated into the dash.
https://www.sau.com.au/forums/topic/269247-ice-audio-video-project-for-my-m35/
  • Replies 45
Pat has a car there at the moment that I sent him. should be good once its done. (Ausky this is yours.)
look up a thread I did on a M35 a while back. that may give you an idea or two as well.
Can't edit the post.
The custom mount for the iPhone is going to work well, it'll fit in the ashtray and so it gets the stealth factor. I pop open the ashtray and pop in the iPhone and get video and audio through the screen and stereo :)
I'm getting an RCA video out plug mounted in the rear of the centre console as well so I can hook up a secondary screen at my leisure.
ahh youre using the dock in similar fashion to that website that did it for the G35?
was a very nice install if you can replicate that!
Not difficult to do.
Once you are in behind the console, running a chord into the ashtray is quite straight forward.
Was thinking about doing an ashtray mount for my iPod classic, but with the roads I drive on (and the speed I take corners at times), it would put far too much stress through the connection (plus the iPod classic is pretty heavy).
iPhone is a bit lighter, so should work well.
+1 for pics please!
yeah but the iphone is much taller and IMO it doesnt sit in docks as well as the classic (yes i have both as well)
i just chuck my ipod and iphone in the drink holder and use the cable plugged into the headphone socket. actually i should get the aux input cable from chris!
+2 for pics :P
The project is finiched, well this part anyway. I have more plans but this will get me out of trouble.
Iphone has a custom connector/dock in the front ashtray, TV tuner fitted and working fine :blink:, extra Video out cable fitted to rear of centre console so I can plug in another screen for the back seats.
The Iphone sends video to the screen and audio through the stereo so I can listen to my MP3's or have a music video going, or put on Toy Story for the little fella.
I'll have to make some time later to take some decent pics, here's one for starters.
Awesome set-up Houdini, you must be rapped!
I'll get around to getting the TV and Sat Nav fixed one of these days, for now I want to focus on the performance side of things and then worry about entertainment later :ninja:
I like the spot you the iphone docks, I've seen other setup's but they have used the drink holder which sucks if you want to keep it. But I don't smoke so the ashtray is ideal!
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
