  • Replies 43
1 hour ago, GTSBoy said:
It must just be my anti-R33 bent, but I would have said the easy way to identify a Neo head is it will be under the bonnet of a good car.
Haha, I have a stagea not a 33, I used to have a 33, but not anymore
3 hours ago, NEO25T said:
Above exhaust ports 2-3 you should find a number cast, 5l8 for turbo neo and 5l7 for non turbs
I’ve still got to pull everything off the motor to see it, factory manifold is in the way I’m pretty sure it’s non-neo though
Edited by 33_drift
Non neo has a four bolt plate on the vct cam pulley, neo has a single bolt. If no cams are installed the non neo will have two big oil feed holes for vct in the cam journal orientated transversely. The neo will have two small oil holes orientated longitudinally with the head.
15 hours ago, 33_drift said:
So I have a stagea that’s blown a head gasket and I’m looking for a head, I’ve looked for the casting number in the place that’s specified and there’s no number that I can see, is it cast into the head or stamped
Would you sell your old neo head?
R33 Has a metal Mitsubishi CAS 23731 02U11
Neo has plastic Hitachi CAS 23731 5L 300
Are you sure your head can't be repaired?
4 hours ago, iruvyouskyrine said:
Then why do you want a neo head to put on to it? Neo head on non neo bottom end = bad times
I don’t want to put a neo head on my motor, I just asked the question to make sure I didn’t buy the wrong head for my car
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
    • lights are on just the one click.
    • Absolutely matters because, while a temperature change will eventually reach a sensor at the end of a static line, the response time is far far far too slow to be useful. Might as well not have a temp gauge at all.
    • When I was eyeing off the 370GT (after deciding I didn't want to spend 30-40k+ to relive my early 20s in an R33) I thought it'd be a good project to add a turbo to it. Now that I have a 370GT, and I've had a couple of chances to open it up, I'm pretty stunned by how much power it makes 🫠 Honestly, the way the VVEL opens it up, it almost feels like there's a little turbo tucked away in there somewhere. It's like Nissan looked at VTEC and said "hold my beer" 😁 Has anyone thrown a turbo into their 370Z or 370GT? Is there a conservative boost level you can run without having to upgrade the fuel system, or are bigger injectors and a bigger pump a given?
