Mine supposedly has 270bhp at the wheels. Jacky's S15 290bhp at the wheels. My horses sound lazy compared to his. lol But his times make my head hurt. I've been to EC so I know how fast 1:45 is! And that's on Federal RSRs! unbelieveable
Might be worthwhile doing a wheel/tyre swap for a session? He's punting his this around very quickly! Callum's is pretty close to yours on "spec" isn't it Harry?
he's 4 stud, so we can't swap rubber. I have been offered me a try before you buy deal though :ermm:
His is also stripped out, some basic aero - wing and undertray/splitter. It went a sec faster from them alone. Lower diff ratio (like I had in the old car) and a mech diff. I have none of those things.
I ran one day in a Scirroco at Nurburgring with some Bridgestone street tyre, then the next day on those Federal 595 RS-R, they are a very good tyre. I dont think they give away much at all to an RE55, which appear to be showing their age compared to the newer A050.
But, the RS-R was an amazing thing...its is a true semi... so that experience combined with the times at EC and Wakefield of the E85 sniffing S15...then they are on par with RE55s in my eyes. At least close enough that it would be interesting to back to back them as the differences are not obvious
The new Federal semi FZ-201 in medium compound is about 1.5 sec faster than RS-R's :ermm:
With a hardness rating of 140 it falls short of some of the true semi's Roy.
It is the best all round (street/track) tyre I have ever used but it is at least 1 & 1/2 seconds slower than the direzza,s I replaced them with.
So the new Federal semi is widely available now?
I was enquiring about them a few months back and they were nowhere to be found.
no. 255 x 17 is still the biggest they are importing atm.
They only have a couple or so of sizes available.
140, 50 or 230....dont care. They are a good tyre and only a guide. There is more to grip then a number or how soft they are. They work well. And if you have used them back to back with RE55s and they are 1.5seconds slower then i fair enough. But i would be surprised if that was the case
Not arguing as to wether they are good or not Roy. A great tyre. My quoted times were actual time differences I ran from one track day to the next.
The rsr's were amazing compared to the street rubber i used prior but the dunlops semi's took grip to a whole nutha level.
I almost have, i used to have 595 rs's on the skyline for street tyres and re55's for track. There was a couple of seconds in it around wakefield on the same day. Don't know that there is a significant difference between the old rs and the new rsr.
Buger all that I could tell Dave, Maybe a 10th or so at best.
Have a hard think... the only difference was tyres? If so then I seems i am selling the RE55s short :) That is dramatic and i wouldnt have thought it would be that dramatic. But a back to back is more accurate then my seat of pants! They were the 595RSR, not the 595, or the 595 EVO etc etc (just checking)
http://www.federaltyres.com.au/ss595
Edited by Roy
Definitely the RSR Roy, I have been a big fan of them as a street/track combo tyre for a long time but as a track only tyre they fall short of the dedicated semi's.
Probably the reason why federal are in the process of introducing the new semi as used by callum earlier in this thread.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
