another vid from my 180SX at Lakeside today. I was trying a wing and splitter. Certainly made a difference, but I didn't really like it. It caused a bit of understeer and didn't improve my lap times, but didn't get heaps of clear laps in.
http://www.youtube.com/watch?v=ZFwnX80YBiw
reduced the angle of the wing. But blew another tyre this session - front right blew out as I turned into Hungry. Resulting off damaged the new front bar, front right gaurd and pushed the splitter into the castor rod bracket which also bent. Its not too bad, but I have some work to do before the Australian Supersprint this weekend.
http://www.youtube.com/watch?v=TjeCn1-CCCE
Edited by hrd-hr30
it was a little, but he did signal me through eventually. Nowhere near as frustrating as the repeated Kumho delaminations though. Not only was this the second blowout in as many events, but it was only the 4th track day since I bought them brand new in March. And it turns out the front left was also delaminated and could have let go at any moment... I got off lightly considering what could have happened if one let go on the high speed sections.
So I had to fork out for new rubber for this weekend's Australian SuperSprint Championships at Morgan Park. Great weekend at a very cool track, with a bunch of fellow SAUer's. Here's some in-car from my nugget S13 - she's looking a bit beaten up after going a few rounds with the Kumhos last week.
http://www.youtube.com/watch?v=-hoXVj1AOnU
More to come...
it was good fun out there. And very interesting to see your own lines from a chase car... I want to do flame-outs like yours :D looks much better than belching smoke lol
outright winner's in-car: http://vimeo.com/16829448
Supercharged Honda powered Elise. Its a different world of performance!
Edited by hrd-hr30
problems were with Kumho S700 slicks, but I hear the V70a suffer the same issues.
In R18 or R17? I remember Dunc (?) saying something about the R18's having that problem in
his door to door racing category, in another thread.
Top work Ash, good to see you handing it to the 4WD's. Love the diving under brakes :D
Thanks Paul.
Its hard to run with the 4wd's on the short track, they put the power down better exiting the tight turns
How are you going? I haven't seen you on the track for a while
Ash
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
