Phillip Island 16-06-2013 After a wet start in the morning the day got better. Still very cold, had a lot of trouble getting heat into the tyres.
Couple of issues spun the rear yoke in the tail shaft in the 1st session. (Carbon Fibre Shaft) For some reason also pumped lots of oil out of the catch can in the same session??? Sorted itself out in the next one???
Lots of time to be had in my driving, but over all great day.
  • Like 1
  • 3 weeks later...
  • 2 months later...
  • 5 months later...
My first time at Nurburgring Nordschleife in a Suzuki Swift (www.rentracecar.com). Awesome experience.
9.30 Bridge to Gantry, more in it with more practice and a clean lap (no oil/yellow flags).
Also went for a taxi lap in the 911 Turbo S (991 shape) Ring taxi with a drive who'd done over 10,000laps. Amazing.
the track was quiet because the lap before it started raining lightly. i figured i'd go out for another lap so went straight back onto the track. aside from the oil spill and having to give way to the renault in the Foxhole it was a clean lap.
I was surprised by the little swift too! only 100kw but it has lots of grip, decent suspension and not much weight. you barely have to brake and it was really fun to drive. lacks the power on the long uphill section in keselchen but you can still carry good corner speed for most of the track. in one of my other laps i was chasing a C63 AMG, he blew away from me on the straights but i could eat him up into corners - i think he was more worried about writing it off than I was though.
LOL...awesome! Cant believe how little traffic you have. I shat myself as I left the pits in the Swift. I thought it was going to roll over on him at speed if I clipped a kerb but was actually an amazing little car!
  • 1 month later...
  • 2 months later...
quiet in here...
Took the Soarer to Mt Cotton last weekend. 48.30. 0.43sec off the Production Road Reg record - mods are exhaust, coilovers and tyres. And my final sector of that run was 0.35sec off my best time for that sector - got too sideways coming back over the crest into the RH turn just before the finish...
footage from my car - the fastest run of the weekend first then a few with little stuff ups:
footage from the side of the track including a nice slide over lover's leap:
  • 7 months later...
    • I would be very confident that they are the same parts (the 2 different SKUs). It seems very clear that you can drop the cam in the 2-way opening, or in the other opening. If you arrange it in the other opening in the same way that you see any other 1-way diff, ie, with the flat of the cam up against the 1° side of the opening, then it would work as a 1-way. It can only spread the ramps when driving forwards - cannot spread the ramps on overrun. It would then appear obvious that if you put the cam into the opening "backwards", that you would get the angled flats of the cam working onto the "points" of the 1° side of the opening, which would give you ramp spread in both loading directions. I do wonder if the forward direction of the 1.5-way config is equivalent to the forward direction of the 2-way, seeing as the cams are flipped and the angled surfaces on those would need to be the same on each side - AND - clearly when installed in either the 2-way or 1-1ay configuration they are not intended to work exactly the same (the ramp angles on the 2-way are 10° different between forward and backward, and the ramp doesn't exist in the 1-way config). 'twere me, I think I would rather actually have a set of rings that offered the 2-way with two different sets of ramp angles, say the 55/45 of the existing design and maybe a 45/37.5 combo for a less aggressive effect), AND another set of rings with a dedicated 1.5-way opening and a dedicated 1-way opening. The 1.5-way opening would actually have the steeper angle on the overdrive side that causes it to be less pushy than the forward drive angle, like you see in many other diffs. But really - if this Nismo thing is thought out properly and all those surfaces work on each other the way that they need to, who am I to argue?
    • Yuh, but that one is NLA. There might be an equivalent, but I haven't looked.
    • If you hadn't bought a stand alone one already, nismo make a bolt on adjustable FPR https://www.efisolutions.com.au/nismo-fuel-pressure-regulator-sr-rb-s13-180sx-r32
    • I know and understand they are principally the same. They both cause lock under decel, but the 1.5 nomenclature implies "half" or less locking force, or it allows for more slip or a speed differential between both wheels. Right now the driving manners with the 2 way is pretty rough on transient to full off throttle in the backroads. In other words letting off the throttle too rough is not forgiving, great for drifting, tougher for controlled grip driving.      Yeah, I have watched that video a couple times, I am more so just looking for the confirmation that both part numbers offer the same ramp architecture and are just different settings from the factory.     38420-RSS15-B5  38420-RSS20-B5
