Hi Fellas,
Some of you may know, I recently got my new setup, it is as follows:
1) RB25/30 Engine
2) GT35R 0.82 A/R Turbo
3) PLazmaman plennum
4) Nismo Injectors
5) GReddy FMIC
6) Nismo 555cc injectors
7) Bosch 040 Fuel Pump
8) 3.5" straight through exhaust
9) Tial 38mm external wastegate
10) Power FC
+ All the other usual smaller mods.
My old setup was just the standard RB25 engine, with the HKS GT2835 Pro S Kit 0.68 A/R, and I had all the other mods, apart from the RB30, the GT35R, and the external gate.
My Power with my new setup is 312 rwkw @ 16PSI
The power with my old setup was 272 rwkw @21 PSI
I took my brother for a drive today, and he agreed with me the car feels much slower than it used to. He said with the old setup, it felt like it was going "warp Speed" haha, but with this new setup, the drive just feels boring.... As you can imagine, I spent over $20,000, so his statement cut me pretty deep.
Anyway, once I wind up the boost to about 24 PSI on this setup to acheive a result of around 370 rwkw, do you think that rush feeling will come back?
I am pretty cut and need some advice.
I took the liberty of plotting the curve in an excel spread sheet.
The Yellow line "my GT35R" is my current setup.
The red line is my old GT2835 setup.
The blue line is this other fellas setup with simular mods to me.
As you can see, the new setup pretty much follows the exact line as my old 2835 setup at the start, and the overtakes it, so I don't understand how it can feel slower??
It's not just me, I've taken a few people for a drive in this past week and they've said the same thing.... it's cutting me up...
ANyway, any help would be appreciated.
Cheers.
mmm... there may not be anything wrong, but yeh, torque to me is more important then kw...
torque is that smack bang feeling that pulls you back into the seat when u hit boost... thats what we all like...
it may have been that the other one produced more, or more likely, it all came on in one big hit, where as this one is more gradual...
apart from some tuning, I dont know what u can do to change that?
The tunner only provided me with the power curve, nothing else......
The cams I got are Tomei 256 inlet and HKS 264 Exhaust, with adjustable cam gears.
I didn't have the cams in my old 2835 setup, which makes it even more bizzare.......
Traction?
Also agreed 555 injectors arent huge for 310rwkw setup, Happen to know the injector duty cycle? I would assume your tuner would have told you if he thought it was a problem anyway.
Edited by JiN_MaN
Yeah I know the injectors are getting boarder line. Injector duty cycle is 81% on 312 rwkw, so it's still ok.
Both setups didn't spin in 3rd gear, which is how I am testing/comparing.
ahhhhh the fun and games of upgrades hey fellas...... :blush:
I had an rb25/30 in my vl with tomei poncams and gt35/40 with a 1.06 rear with microtech 600cc injectors, ETM manifold and it made 340rwkw, and it was awesome put ur foot into it in second and it would turn the tyres straight away, id say it was making fullboost by about 3500rpm (18psi) compared to when i had the excat same setup on the 25 bottom end it came on full boost at about 4500rpm!
Looking at your graph it looks very lazy in making power, i dunno what the cause of that is but yeah it looks very slow in making power..
You don't need a torque curve when you've got a power curve - torque is related to power (just power/revs). If it makes the same power at same revs then it's making the same torque.
IF it is indeed making those numbers and it seems LESS linear if anything then perhaps it's all in your head. Are you prompting people to say it feels slower?
wont be the curve, look at the graph. it goes from making less torque, to making more torque across the midle of the rev range, ie, its coming on harder
your imagining it. or something has gone wrong between it being dyno'd and you picking it up. i'm betting its the first one
maybe you had all these ideas about what a RB30DET+GT35 'should' be like and thats thrown out your perception
Not saying it's the problem, but I think your injectors are too small for that turbo.
I've made around 250awkw on EVO9 and EVO10's with 550cc Inj so another two injectors = (250/4)*6 = 375awkw. Thats dyno dynamics figures.
So 550cc injectors are well within the scope of that turbo on std pump density fuel as long as your fuel pump setup is up to it.
I went from a std Rb26 to a RB30DETT with -5 turbos and on same boost as before I would say the RB26 felt more exciting to drive but you compare the actual accelleration rates and you'll find its a completely different story. I'm seeing 80-160km/hr times on a 4th gear roll on of about 5.4-5.6 sec on 12psi of boost before it was about 7 secs.
I can tell you that even on that boost I can get roll on wheelspin in 3rd.
Traction?
for 310 pulp 555's are fine... for 370 that's another story...
Yep, id say its the laggy turbo syndrome.
LAggy turbos that come on really hard will always feel faster since it pulls more G's, but overall it wont be faster on the tarmac.
I've been in 2 similar powered cars, a 240rwkw 33 and a 250rwkw one. Shouldn't feel very different right? wrong! The 250rwkw has nothing under 4 Grand so when the turbo does come on, the G force is way more than what u feeel on the 240rwkw one.
Depends what you like overall, me personally, i prefer more midrange and gradual build up of power as that is always going to be quicker
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
