  • Replies 55
Posted Images
I've been keeping track of my fuel consumption on my iPhone...
Because of work I'm also making lots of short trips of about 10 min / 2 to 9Km every hour or so... ...I think I got around 600Km on a GOR cruise once and around the same going up to Swan Hill... ...But that was before I started recording my fuel...
i used to get approx 450km (30km of that after fuel light on) max. fairly stock auto. haven't had a chance to check economy recently as i've had it tuned, and still in the "honeymoon" phase :D
I don't think I've ever seen the fuel light... ...How low does the needle get before it comes on???...
For my car, it came on when the needle is like about 1/2cm or so under the E line.
& I only know this because when I picked up my car from the panel shop, they pretty much drained all the fuel out & I was driving on empty :( .
Thanx JamesK,
i got an autoban just down the road from me, ill pop in there on the weekend and see wat they can do for me about an o2 sensor,
hopfully that might get some more ks, if not, it cant hurt getting a new one :)
Forget autobarn, save some $$$ and time and order from HERE $77 and quick delivery.
I've never been brave enough to let it get that low... :(
Dont you mean stupid enough, efi fuel pumps dont like running dry.
Replaced the oxygen sensor tonight. Got her up on the hoist and laughed at why I even bothered putting it up there when the sensor was clearly visible from the engine bay. Then I ate my words when a seemingly 2 minute job turned into 2 hours. The positioning of the sensor is so damn awkward. Near impossible to get a grip on the sensor nut with a torque-worthy tool. My open ended spanner kept slipping...shifter couldn't get a grip...socket wouldn't fit over sensor. Didn't want to thread the sensor nut so I resorted to snipping the sensor wires in order to get an angled ring spanner over the nut (forcing me to get the new sensor installed or being unable to drive home). Still had no room to get any decent leverage though. Had to remove the heat shields from turbo and exhaust - the screws of which were rusted through and threaded themselves when I tried to remove them. Drilled some of them out and vowed not to put the shields back on afterwards. I was quite literally bracing myself against the car chassis while trying to unhinge that rusted piece of crap sensor. After every swear word in 4 or 5 languages she finally cracked. Putting in the new one took the other half of the 2 minutes I had originally intended to spend on this.
/end rant.
Here's hoping my fuel economy improves because my anger management sure isn't.
Oops should of posted up earlier I have an O2 Sensor socket if anyone nearby wants to borrow it...it does make your job a crap load easier as birds may have found out that damn thing is in tight!
My sky is on average on about 11.4L which i was happy with UNTILL my car broke down and started driving my brothers spare care, 1.8L Corolla. Geezzz, fill 40 L, done 550kms and i still got one line to empty. I cant belive the difference. You save about 7 dollars per 100kms. woow
In saying that, the car has no balls nor handling nor looks nor anything else. lol just a lil engine.
ive never seen a fuel light come on ever..
didnt know there was one
There is guys, trust me I was in the same boat as you guys but it only comes on when your needle is ON E like basically the light is REFUEL NOW!...haha but in the manual it says there is 7 or so lts left in the tank and even when your start to get at that level it will still start to fade on and off until I think about 5lt
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
