  • Replies 55
Posted Images
I've been keeping track of my fuel consumption on my iPhone...
Because of work I'm also making lots of short trips of about 10 min / 2 to 9Km every hour or so... ...I think I got around 600Km on a GOR cruise once and around the same going up to Swan Hill... ...But that was before I started recording my fuel...
i used to get approx 450km (30km of that after fuel light on) max. fairly stock auto. haven't had a chance to check economy recently as i've had it tuned, and still in the "honeymoon" phase :D
I don't think I've ever seen the fuel light... ...How low does the needle get before it comes on???...
For my car, it came on when the needle is like about 1/2cm or so under the E line.
& I only know this because when I picked up my car from the panel shop, they pretty much drained all the fuel out & I was driving on empty :( .
Thanx JamesK,
i got an autoban just down the road from me, ill pop in there on the weekend and see wat they can do for me about an o2 sensor,
hopfully that might get some more ks, if not, it cant hurt getting a new one :)
Forget autobarn, save some $$$ and time and order from HERE $77 and quick delivery.
I've never been brave enough to let it get that low... :(
Dont you mean stupid enough, efi fuel pumps dont like running dry.
Replaced the oxygen sensor tonight. Got her up on the hoist and laughed at why I even bothered putting it up there when the sensor was clearly visible from the engine bay. Then I ate my words when a seemingly 2 minute job turned into 2 hours. The positioning of the sensor is so damn awkward. Near impossible to get a grip on the sensor nut with a torque-worthy tool. My open ended spanner kept slipping...shifter couldn't get a grip...socket wouldn't fit over sensor. Didn't want to thread the sensor nut so I resorted to snipping the sensor wires in order to get an angled ring spanner over the nut (forcing me to get the new sensor installed or being unable to drive home). Still had no room to get any decent leverage though. Had to remove the heat shields from turbo and exhaust - the screws of which were rusted through and threaded themselves when I tried to remove them. Drilled some of them out and vowed not to put the shields back on afterwards. I was quite literally bracing myself against the car chassis while trying to unhinge that rusted piece of crap sensor. After every swear word in 4 or 5 languages she finally cracked. Putting in the new one took the other half of the 2 minutes I had originally intended to spend on this.
/end rant.
Here's hoping my fuel economy improves because my anger management sure isn't.
Oops should of posted up earlier I have an O2 Sensor socket if anyone nearby wants to borrow it...it does make your job a crap load easier as birds may have found out that damn thing is in tight!
My sky is on average on about 11.4L which i was happy with UNTILL my car broke down and started driving my brothers spare care, 1.8L Corolla. Geezzz, fill 40 L, done 550kms and i still got one line to empty. I cant belive the difference. You save about 7 dollars per 100kms. woow
In saying that, the car has no balls nor handling nor looks nor anything else. lol just a lil engine.
ive never seen a fuel light come on ever..
didnt know there was one
There is guys, trust me I was in the same boat as you guys but it only comes on when your needle is ON E like basically the light is REFUEL NOW!...haha but in the manual it says there is 7 or so lts left in the tank and even when your start to get at that level it will still start to fade on and off until I think about 5lt
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
