  • Replies 69
For those who can read Japanese, can you please translate the first option?
I know that the second option is the pop-up screen.
I assume that it is leather, but can someone please confirm this?
Edited by iamhe77
This is the main screen, not sure how to bring up the list of factory fitted options tho ;)
Any one shed some light?
I've just got FAST 2009 JDM up and running if anyone wants a DVD copy :D
Hey Bis-e Bee,
I like the aero kit on your stagea. It looks fast.
Speaking of which, where did you get your copy of Fast 2009? I would love a copy. I have one that i downloaded and it is giving me all sorts of trouble.
Cheers,
Hey Bis-e Bee,
Cheers,
Thanks for the nice comment on my aero kit ;)
I painstakingly downloaded Fast 2009 from a Russian site, 48 files of 100mb each from RapidShare (15 minute wait between each transfer).
If you are going to the meet in 2 weeks, I will have a stash of copies for those interested.
Ouch, thats a bit keen for me.
Where is the meet. I may have to check it out and meet some of my fellow stagarians.
+1 for a copy
http://www.skylinesaustralia.com/forums/Ns...rs-t266253.html
Make sure to lodge your interest if you are going to attend so that you can be added to the list!
STTMQ is 'leather subrare combi seat' ( black )
You FAST is displaying Chinese characters, unreadable, change the font to something like "Kozuka Mincho" for japanese.
My apologies, I had NJStar set to Chinese :)
Is this better?
This is the main screen, not sure how to bring up the list of factory fitted options tho :D
I've just got FAST 2009 JDM up and running if anyone wants a DVD copy :P
i would love a copy, Stephen.Just let me know how much to get one to me in Caloundra,regards graham :dry:
i would love a copy, Stephen.Just let me know how much to get one to me in Caloundra,regards graham :D
Send me a PM so I don't forget!
I'll get around to it in the next few weeks, should only cost a few bucks to post, will advise.
  • 3 weeks later...
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
