I'm upgrading from T517Z 10cm's. I made 399.6rwkw with the T517Z's on a bone stock(internally) 26 on 98.
I like my trust intake, charge and dump pipe kits and I want to stay with low mounts.
Car will be used for everything! Drag(pb 10.6@138), open circut and lots of street duties.
Has anyone made numbers with the T618Z kit?
Dyno sheets?
On road driving experience?
From first hand experience, how do they compare to HKS GTR'S?
Cheers
J
https://www.sau.com.au/forums/topic/271587-gtr-t618z-kit-go-no-go/
how much more power do you want? and how much more do you reckon the stock motor will take on 98RON with old factory internals?
I mean if you can't squeeze any more out of the 517s and you need more power then the 618s are the logical choice really as like you say you can keep all your current intake and exhaust gear.
Ive done a few sets of T618Z's and usually against my recomendations, the engine work required to make them work is extensive... but for your application they might fit the bill.
The T618z's are designed for drag and circuit use and i have personally been in a GTR with the 618's on a well setup TRUST car and it was awesome (700+ps @ 1.8bar), i supplied TRUST's receipe to a shop out sunbury way, including all the parts about 4-5 years ago but due to reasons i cant post it never performed.... shame as it was a waste and had heaps of potential.
Big cams, port work, big boost (they are rated 1.5 - 1.9bar) and rpm are needed to make them work, a nice white street / ciruit GTR here in melb (creatd built) has run low to mid 10's with a custom pair of garrets built by rotomaster to T618z specs... again with a built motor to suit... expect to turn your motor inside out.
Edited by URAS
Heres a dyno shit from autobarn.
HAHA i supplied the information for that flyer years ago....when i was doing the buying for their stores (TRUST / BLITZ / APEXI etc) I DID NOT supply the fit times though :cheers: ..... i think if you look at the Td06-l2 kit flyer for SR20 they just stole it from that :P
some of the said receipe is included in that flyer.
Edited by URAS
Thanks for the input thus far guys.
I should have stated that a built motor is on the way.
AND on that note, has anyone tried sleveing a stock block with good results???? I want to keep the origional block and head in the car if I can, but I know it willl split at 500rwkw at 2 bar + .
hey whats the finned alloy doo dacky in the braided above the intake runners for cylinder 1&2 ?
That's a super, metabolic, fuel particle, atomatizer device to keep the molicule chains in a row and the fuel atonomous.
Fuel filter..
I upgraded my T517z to a T618Z a while back.
I lost a bit of bottom end and gained a lot more at top end as expected.
It's on a 3L so it's not laggy at all.
I would love to know how these compare to the HKS GTRS though.
When do you start making usable boost with the 3lt? What was the diffrence in respose roughly? 300-500 rpm???
Don't suppose you have a dyno sheet?
Cheers
J.
I had to sleeve a block a while back to keep standard size bores....I can't imagine any other reason you would do it though. the standard block, properly prepped, will make to 500+ you are talking about
    • Hi guys, Making some space/cleaning up. A whole heap of random OEM R33 GTR parts and other random bits and bobs. I will update this thread as I go. Parts are located in Moorebank NSW 2170. Pickup preferred but will post at buyers expense. Prices are negotiable. If they don’t sell it will go in the bin. Item 1: BOV return pipe. $40 Item 2: RB26 cam gears. $20 Item 3: R33 GTR torque split, oil temp, boost centre gauge. $100 Item 4: RB26 fuel rail x 2. $20 each Item 5: RB26 Recirc valves. $50 Item 6: OEM upper front arms. $20 Item 7: Royal Purple Max Gear 75w-140 1 quart/946 ml x 5. $50 each or 5 for $200. Item 8: OS Giken 80w-250 diff oil 1 litre. $25 Item 9 Eibach springs. ers-11-140-60-0140. $100 https://www.streetfx.com.au/eib140-60-0060-eibach-ers-140mm-length-x-60mm-id-coil-over-spring?_ga_campaignid=22235933977&_ga_adgroupid=180146800292&_ga_keyword=&_ga_device=m&_ga_target=pla-295238231169&_ga_locint=&_ga_locphy=9071723&_ga_matchtype=&_ga_network=g&_ga_device=m&_ga_placement=&_gcl_id=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE&gad_source=1&gad_campaignid=22235933977&gbraid=0AAAAADPiTbo1xAuvnjIWWYnezivf-BUSY&gclid=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE
    • That's kind of what I was getting at saying you'd be here soon regarding length etc being able to add additional restriction.  My assumption (possible donkeys of you and mption) is that the length of hose to an oil cooler, and back, isn't going to be that huge of a loss. Typically you're talking about 1.5m of total length. And so far everyone in our world hasn't had issues with oil not being able to get to a cooler and back, it's more been, how the heck do we get the oil out of the head and back down to the bottom? I'd nearly hazard a guess the biggest issue people have with oil cooling and oil supply, is being able to get the heat out at the cooler itself (not enough air flow, too small of a cooler etc) Also, when people mount them wrong and make really awesome air traps so they've dramatically diminished the cooling capacity.
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
