Ill certainly ask Hypergear. Just reading through the sites you linked, it would seem the SS1 and SS1 billet machined turbo are the best match for what I need - maximum low end response. Anyone using those models?
What are your power goals?
Modest, in fact not much more than stock. I was running 9psi, and I think Ill be leaving the stock ECU, hence why I am looking for a close-to-stock replacement (a bolt on replacement). Torque and boost rolling off at higher rpms isnt a big deal since its a daily driver, meaning I also want to keep low end response as good as possible. If I get some stronger midrange torque, then thats nice too.
Any info on why the GCG option doesnt end well?
Also my understanding is that these hypergear units (SS1) are new turbos, but still cheaper than GCG where you have to send your existing one off to be modified.....
I hate to be 'that guy' but changing the Turbo at all, in any way, in any form, in any possible configuration means you should immediately obtain a tunable ECU. Do not do it otherwise.
If you simply want a replacement turbo that will run fine on the stock ecu, let Stao know and he will make a stock sized highflow.
The GCG units are generally GT3076 cores stuffed into factory housings. You said you don't want lag... Garrett BB cores don't like the high thrust loads usually found when stuffing such large cores into small housings. Hypergear generally use bush cores for this reason.
Stao can highflow your core, or supply a complete turbo. Up to you. Ring him or message, and have a chat about your options.
Out of interest, isnt a hi-flowed turbo effectively a different turbo? The SS1 turbo I was referencing seems to be a close match to stock, certainly comparable to the hi-flow modified one.
"Hi flow" is a loose term for a rebuilt turbo which may in fact be rebuilt to original specs or to produce a little or a lot more power. Hypergear can build to your requirements so an email or a phone call would be a good place to start.
Yeah, Ive already sent an email. Even the standard hi-flow they list says the compressor and exhaust wheels are replaced with larger steel wheels, hence my question that isnt a new turbo which closely matches the characteristics of the original effectively no different to the ECU (if a high flowed one is fine on a stock ECU)?
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
