Hey guys.
So I am going to submit the order to Denso next Friday.
Currently have;
Cussco x 6 plugs
Liam s x 6 plugs
Daleo x 6 plugs
Anyone else, please add your name to the list.
I will PM my account details next Wednesday with shipping costs (express post - should be able to keep it under $10 per set).
Please make sure you have PM'd me your shipping address prior to that (may be helpful).
Cheers.
  • Replies 43
Hey guys.
Postage will be via Express Post once I receive the plugs and will be bubble wrapped for safe transport.
Postage cost is $8.50 anywhere in Aus.
Please confirm via PM by 6pm this Friday (12/6/09) if you want a set.
I will place the order once I have received everyone's payment.
Total cost will be $104.50 to your door.
Denso state that these plugs are good for 150,000kms or around 1.5-2 times longer than Platinums.
:P
Edited by iamhe77
Better count me in, not sure whats been done to my m35 and i better get it running good, i should call up the service sticker i have on the window and find out whats been done to it.
Whats the Part number for this plug?
Hey guys.
:P
I would love to get in on this deal, is it too late? Put me down for six if possible. I would pm but aren't allowed yet? :P
Thanks.
And received! :banana:
Payment received;
Scotty nm35
Daleo
Waiting for bank to complete transfer;
Liam s
"Angus Smart" and "Cussco".
Are you guys in or not?
Once the bank completes the transfer from Liam s, I will be paying for and ordering the plugs.
If anyone is still thinking that they may want to order some. Time is nearly up!
The order was paid today & sent to Denso Japan where the plugs need to be made up.
Daleo
scotty nm35
liam s
Will send them out to you the moment I have them.
Should be between 10-12 weeks as stated previously.
liam s you have a PM.
  • 1 month later...
Update.
The plugs arrived at Denso today, but I can't get there to pick them up until Monday morning.
I will Express Post them out on Monday, so you guys (that paid) should have them by Wednesday at the latest.
  • 11 months later...
Okay guys, so I am doing another group buy on Denso IKH22 plugs.
Those that are interested, please let me know ASAP.
I will be ordering on the 2nd August and will require full payment prior to this date.
As before, there is a 3 month lead time on plug delivery.
Unfortunately the price has increased slightly :happy: so total cost shipped to your door will be $114.50 for a set of 6 plugs.
These plugs are stated to be good for 150,000kms.... but I would still change them out every 80-100,000kms.
If interested, let me know either here or PM
  • 1 month later...
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
