Might be worth investigating what another one is worth, if they are cheap then add in the power and see how it goes. If they are a fortune a cooler might be a good option, also have a chat with some of the 4wd shops for what they are doing with them.
Blokes on a Challenger forum have driven their bone stock autos loaded up and towing caravans around Australia with no problems so I reckon mine should be OK on tarmac roads towing 2000kg all up max. But an auto trans temp gauge might be good, will check that out. Don't want to add stuff that is apparently not necessary, spare $ go to racecar :)
So cbf reading bucket load of pages!
X trails....say 09 on wards diesel.
I've noticed that the autos are 1350kg towing and manuals are 2000kg towing. What's reason behind that? And I guess towing the mx5 and trailer, would it be that hard on the manual?
Seen a few around 20k to 22k which don't seem too bad.
Reduced towing for the auto usually is because the auto is the transmission weak link. Torque is what matters with a diesel, I'd say 300nm minimum for your application.
Xtrails won't be happy towing - they'r all kinds of shyte.
If it's a very light car on a very light trailer (say total 1300-1400kg) you might get away with it. If you're considerint towing up to 2 tonne then forget it. Xtrails only just make the cut as a family car. They're not designed to tow.
Chris,
This might help you, is the petrol versions I think so deisel would be better
http://caravanersforum.com/viewtopic.php?f=2&t=4842
New Jeep Cherokee on special offer, $30k for the four speed auto V6 petrol (diesel with five speed auto is an option) drive away, 2270kg towing capacity. http://www.jeep.com....cherokee-towing
Edited by 260DET
$30 k is cheap for a base model which (I think) is being run out. It's a nice car and would do the job if you're towing something light like an mx5 and light weight trailer.
For example, my Jeep Grand is rated to tow 3.5 tonne, but I personally can't imagine towing that kind of load. I tow a 33 gtst with a 750kg trailer and various bits and pieces. I reckon around 2.5 ish tonne is my personal limit, giving a bit of overhead or buffer.
Pretty sure it was suggested there may be some other options some pages back?
Again - the Cherokee still very cheap! Wonder if you can get stock?
personally i wouldnt touch a jeep, the missus wants a wrangler and i am spewing, terrible fuel economy, parts are expensive and depreciation is one of the worst on the market.
it depends though, if you only drive her once or twice a month and you dont care about fuel consumption get a 100s v8 land cruiser
$20k should get you a nice one
my cousin has been towing his 1800kg boat in his ls1 wh statesman for years and it purrs along the freeway
$5-10,000
07 v6 hilux dual cab sr
15-20.000
id take a hilux anyday of the week over a navara, triton, colorado or mazda for that matter
even a v6 territory you can have for around the 10-13k mark for a decent one
but def no jeep
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
