Might be worth investigating what another one is worth, if they are cheap then add in the power and see how it goes. If they are a fortune a cooler might be a good option, also have a chat with some of the 4wd shops for what they are doing with them.
Blokes on a Challenger forum have driven their bone stock autos loaded up and towing caravans around Australia with no problems so I reckon mine should be OK on tarmac roads towing 2000kg all up max. But an auto trans temp gauge might be good, will check that out. Don't want to add stuff that is apparently not necessary, spare $ go to racecar :)
So cbf reading bucket load of pages!
X trails....say 09 on wards diesel.
I've noticed that the autos are 1350kg towing and manuals are 2000kg towing. What's reason behind that? And I guess towing the mx5 and trailer, would it be that hard on the manual?
Seen a few around 20k to 22k which don't seem too bad.
Reduced towing for the auto usually is because the auto is the transmission weak link. Torque is what matters with a diesel, I'd say 300nm minimum for your application.
Xtrails won't be happy towing - they'r all kinds of shyte.
If it's a very light car on a very light trailer (say total 1300-1400kg) you might get away with it. If you're considerint towing up to 2 tonne then forget it. Xtrails only just make the cut as a family car. They're not designed to tow.
Chris,
This might help you, is the petrol versions I think so deisel would be better
http://caravanersforum.com/viewtopic.php?f=2&t=4842
New Jeep Cherokee on special offer, $30k for the four speed auto V6 petrol (diesel with five speed auto is an option) drive away, 2270kg towing capacity. http://www.jeep.com....cherokee-towing
Edited by 260DET
$30 k is cheap for a base model which (I think) is being run out. It's a nice car and would do the job if you're towing something light like an mx5 and light weight trailer.
For example, my Jeep Grand is rated to tow 3.5 tonne, but I personally can't imagine towing that kind of load. I tow a 33 gtst with a 750kg trailer and various bits and pieces. I reckon around 2.5 ish tonne is my personal limit, giving a bit of overhead or buffer.
Pretty sure it was suggested there may be some other options some pages back?
Again - the Cherokee still very cheap! Wonder if you can get stock?
personally i wouldnt touch a jeep, the missus wants a wrangler and i am spewing, terrible fuel economy, parts are expensive and depreciation is one of the worst on the market.
it depends though, if you only drive her once or twice a month and you dont care about fuel consumption get a 100s v8 land cruiser
$20k should get you a nice one
my cousin has been towing his 1800kg boat in his ls1 wh statesman for years and it purrs along the freeway
$5-10,000
07 v6 hilux dual cab sr
15-20.000
id take a hilux anyday of the week over a navara, triton, colorado or mazda for that matter
even a v6 territory you can have for around the 10-13k mark for a decent one
but def no jeep
    • Hi. This is just my curiosity because iam sure the tuner figure something out...but either way i want to ask. The "problem" is that the Nistune ECU (Stagea FW and RB25DET NEO from Stagea) sees many times the speed than the speedo does(he says the speedo show 120 km/h - correct speed and the ECU shows like 510km/h ) I told him that this car/tranny getting speed from rear diff. If iam not mistaken the RB25DET NEO "need" to see tranny speed sensor? (my tranny has the plug for it). So couple of "question" If he connects/wire the speed sensor to the tranny...are the signals gonna intervene and if...what if he disconnects the rear diff one and the speedo stops working? Or the "new" sensor from the tranny "take over" and will not going need the one from diff? As i said i know he figure/get that done...iam just curious to know what are the solutions 🙂
    • Your IACV is set to idle too low. You need to adjust it via the screw Duncan mentioned. From memory it should be 650rpm with the valve electrics unplugged. What is it trying to idle at with the IACV plugged in?
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
