personally i wouldnt touch a jeep, the missus wants a wrangler and i am spewing, terrible fuel economy, parts are expensive and depreciation is one of the worst on the market.
it depends though, if you only drive her once or twice a month and you dont care about fuel consumption get a 100s v8 land cruiser
$20k should get you a nice one
my cousin has been towing his 1800kg boat in his ls1 wh statesman for years and it purrs along the freeway
$5-10,000
07 v6 hilux dual cab sr
15-20.000
id take a hilux anyday of the week over a navara, triton, colorado or mazda for that matter
even a v6 territory you can have for around the 10-13k mark for a decent one
but def no jeep
Your vehicular knowledge knows no bounds.
Mate has a JK Wrangler Rubicon Petrol, returns 14lltrs per 100k's towing on 35" tyres. Most reliable 4wd in our group of tow car's.
I use a GU Patrol, awesome for it, also on 35" tyres so struggle's a little on hills, but after towing with it, i will never use anything smaller.
As long as the GPS did not direct you to drive into the sea :)
On the Challenger, looks like the auto has a dual cooling system, through the engine radiator first then to it's own radiator. Crowded in front of the engine radiator - a/c, IC and auto cooler.
FYI, Navara D22's are on sale.
Top spec STR dual cabs are rolling out at under $28k drive away with 12 months rego. Bloody good buying I reckon. The D22 is a much better thing since getting the 2.5L donk. Still some way short of a D40 to drive, but at virtually HALF the price.........
2800kg towing capacity.
http://www.nissan.com.au/Cars-Vehicles/Navara-D22/Offers
http://www.nissan.co...vara-D22/Offers
... but do they have stock? Probably... I guess that's why they are on sale.
The last time I looked at them (about 18 months ago) all I got was attitude and you " you need to wait".... at the full RRP.
My local dealer has 2 in stock. Next dealer along has 3 apparently......
You not driven a Great Wall?
I'm not buying a D22, but they're much better than a China ute, and now they're priced like one.
I've heard a horror story about the Navara (not sure if D22), multiple transmissions, multiple diffs, spent most of its warrantly life in the dealership.... The guy said the arrogance and lack of care by the manufacturer scared him away from Nissans forever.
Not sure if blackrex had similar issues. Maybe its worth staying away from one?
Then again, I guess most brands will have horror stories.
Mine kept on failing in the front suspension, snapped two torsion bars (they lose their spring after about 10k k's, and the car rides on the bump stops after that) I could never keep the bolts tight in the suspension linkages, even after lockwiring the nuts/bolts in place and the engine wore out the bores after 80k k's. The car was always serviced by Nissan at the correct schedules, but it was never really reliable.
not really a tow car story
but...
Took the q7 to Stockton beach on the weekend good fun
Did it easy even on 20's and 40 psi
Front lip was in danger a few times though. many funny looks from fellow 4wd's (while ripping hellis)
GPS freaked out as well
Me old Jeep had a really easily removed front lip spoiler (no tools required).
3rd gear, low range (to fully disengage stab control), and rev limiter. :D
was talking to one of the regulars at work today. his mate has a new Q7 in NZ. he had it for about 2 weeks before his missus clipped a gutter and shagged a tyre. $1300 later........... then the following week a vallet at a carpark hit a gutter or something and shagged a rim (took a big chunk out of the lip of the rim). also within the first month of having it he had the bike rack on the back and accidently hit the boot release button and it opened up into the bike rack, putting 2 dings in the boot door. i guess that's a bit of karma catching up after he won 31 million in lotto at the start of last year............
My old man has a 2004 D22 navara STR with the 3.0lt turbo diesel, manual 5 speed box, and it has been the most reliable car he has ever had. It is a work vehicle that tows 2 tonne regularly (once a week), and has done 250000 without anything major gone wrong. Perhaps it is the 2.5cr that isn't as good?, He tested both at a similar time and he said the 2.5CR (common rail) didn't "feel" as good as the 3.0. I also heard that the 2.5CR was primarily manufactured in Spain, while the 3.0 was made in Japan. Whether that has anything to do with build quality is anyone's guess.
Edited by Grimesy
yea i bought a bike rack that is spaced so thats not a problem
mind you when the bikes are on the car is about the length of a football field then
marlin
have done lots of hoops in jeeps they skid hard
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
