I feel weird saying I have a bit of badge snobbery by leaning toward the Hyundai :P
Toyota FJ is basically a Prado underneath I understand, so should serve you well.
They're but in the USA? Does that explain why no oil burner donk?
hello friends,
am looking at buying a diesel tow car/4wd with a budget of 10 -> 15k. it would be towing my S14 on a car trailer.
i was leaning towards a 80's series landcruisers post 96 were the tow rating was changed - what are opinions on these?
can anyone please suggest some other options that would suit my price range?
cheers
hello friends,
cheers
Are you needing anything else from the vehicle other than towing ability?
Seating capacity, daily driver, economy requirements........ ?
not so much, mainly just towing and off road ability for some fun
half decent fuel economy would be nice but i have a daily also so not essential.
cheers
Well as soon as you say "off road ability" which I reas as "serious off-road ability" I instantly think live front axles.
So, 'Cruisers and Patrols are on the menu, wagons or utes depending on what suits. Avoid British shit but we all know that.
Don't get carried away with lifts etc, coz the higher you go and the bigger the tyres, the worse they tow.
Diesel Cruiser or Patrol, aftermarket turbo kit if it doesn't already have boost. Budget i9s the hard part.
Personally, I'd be having a crack at busting this bloke's chops, or trying to find a GU Patrol ute with 4.2 turbo.
http://www.carsales.com.au/private/details/toyota-landcruiser-1994-14020428?base=1216&vertical=Car&cr=10&eapi=2&__N=1216%201246%201252%201247%201282%204294962861%204294962570%204294680273&num=15&silo=Stock&Range=Price%3a10000%2c20000%7e0.5&sort=default
yeah 'serious off road'
wow at that link. 20k seems pretty crazy. newer versions are much cheaper here in perth >.<
not sure it would be up for the towing capacity either
pretty much what i thought - will target the cruisers and pooohtrols
cheers mang
cheers mang
New ones attract less money because they have the shitbox ZD30 in them and will blow up. If you read back I rave about my 4.5l dual fuel Pootrol quite a bit, but think it is justified, I get 18/100 driving daily, heaps cheaper to buy and run day to day than a diesel, and debatable how much more it costs towing.. The 4.8l is a heaps better motor again
8.4L/100 is good for a truck, how does it drive.
Now have a trailer for the Challenger, PI over easter is the plan. It's going well, only thing is the suspension needs tuning for Aussie roads. Thinking about getting a set of Bilsteins to improve it.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
