Any of you guys had any issues with your wipers?
There seems to be a little slop in the mechanism that when running on intermediate the wipers stutter on return. Not sure if its just the cheap blades or if its wear in the motor assembly its giving me the shi#s.
https://www.sau.com.au/forums/topic/272328-m35-wipers/
No trouble at all, infact the smoothest operation i've ever had. I know what you mean, the wipers on my truck are doing that when there's not much water on window, really annoying! I'd splash out on some new blades.
https://www.sau.com.au/forums/topic/272328-m35-wipers/#findComment-4627402
Just put a new blade on, I replaced it the first day I got my car...
As I was going
BOSCH Areo Twin blade is the best I have ever used...
450mm and 530mm is what you need for a perfect fit for our car...
i bough them for around $ 25 each at supercheap auto!
cheers.
https://www.sau.com.au/forums/topic/272328-m35-wipers/#findComment-4629317
  • 1 month later...
know what you are saying exactly -- annoying stutter! mainly on intermittent ... dont think its the blades .... any luck finding out why?
https://www.sau.com.au/forums/topic/272328-m35-wipers/#findComment-4702467
I haven done any more research into my problem. I just dont use the intermitant. Its very weard as some times I think thyat it is the way it is controlled. Now and then I will get a quick 2 wipes in the int function.
I was going to pull them apart and see if I could reduce the slop.
By the time I get around to it I wont them anyway
https://www.sau.com.au/forums/topic/272328-m35-wipers/#findComment-4702970
Mine had this problem when I bought it, I pulled the mechanism out and found the plastic ball cup was worn/broken. I replaced them with rose joints, then they worked smooth.
I have one spare plastic cup now.
The assy isnt hard to get out to check.
https://www.sau.com.au/forums/topic/272328-m35-wipers/#findComment-4703303
The problem with me is that I dont have time to be messing around with it.
I will try to get onto it this weekend.
Whats a rose joint?
https://www.sau.com.au/forums/topic/272328-m35-wipers/#findComment-4703355
  • 4 years later...
Thread dig, but very relevant.
I have a similar problem, and possibly the same cause.
When the wiper changes direction at the bottom of it's travel there is a clunk. Shifting the wiper myself lets me move it about 100mm at the tip. I expect there is a linkage or the above mentioned bush flogged out somewhere giving the joint play.
Any guides or information on removing the assembly from under the plastic cover?
https://www.sau.com.au/forums/topic/272328-m35-wipers/#findComment-7271791
Guys, this is a common problem for 2001-2003 stageas and skylines. you don't have so much dirt on the roads - so your wipers don't used to be as tired, as ours, and it is not common on your sterile roads)
you have to clean power distributor on the wiper's motor to remove gray dirt from the separating point oin the line, supporting the periodic duty!
just look for some pics
this is pic of my first Stagea. don't look at dirt - a wash engine room once in 3 month, but it has no affect...
https://www.sau.com.au/forums/topic/272328-m35-wipers/#findComment-7273282
That's not the issue with his though, the white bushes on the arms flog out on some cars allowing the blades to flop around like a slapper's arse. ;)
Never seen those contacts being a problem on the 80 or so V35's/Stagea's I have worked on, can't be a very common issue... Perhaps it's the snow buildup on the blades in winter over there causing excess current draw?
https://www.sau.com.au/forums/topic/272328-m35-wipers/#findComment-7273325
Scott, difficulties in translation) i missed with a problem)
the problem i wrote is only for 2001-2003 cars with mileage over 200 kkm - probably, you are right, hard work with snow matters
white bushes are too easy to find as a reason, for our severe circumstances)) - in Russia original spare arm with two bushes is around 10USD, replace and forget
https://www.sau.com.au/forums/topic/272328-m35-wipers/#findComment-7276267
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
