  • Replies 40
im not going to attemt all this by myself as i am not experianced in working on the vehicle myself. trying to elarn but yer... lol. and it doesent help when i have a hybrid pipeing systam wich pretty much wont let me access my coilpacks lol.
thanks =)
I've got almost no mechanical knowledge and i still managed to put in Splitfires and new plugs in my car. I've got a hybrid kit as well but it didn't pose any extra trouble. Hardest part is getting clear access to them, once you've got to them rest is easy. Think there are a few guides floating around on here too if you do a search.
https://www.sau.com.au/forums/topic/272440-j-racing/page/2/#findComment-4637537
  • 1 month later...
Provided its small, direct jobs which require little instruction (attach front bar, paint car etc) Jerry does a good job, and if he stuffs up he will fix it for free. But do note that he doesnt do mechanical or electrical anymore. He will send your car to Fast and Furious automotive for anything mechanical and will get a 3rd party electrical to do anything electrical.
But when it comes to bodykits, paint work, customising bodykits (he even makes some of his own) and anything external he is great.
https://www.sau.com.au/forums/topic/272440-j-racing/page/2/#findComment-4755913
  • 4 weeks later...
So in Canberra there is:
ESP
Trojan
Autotech
Ultimate Tunes
J Racing
Anywhere else? It would be good to compare the hourly rates of each place also.
I need a pair of turbos (probably -5s), them to be fitted and the car tuned.
https://www.sau.com.au/forums/topic/272440-j-racing/page/2/#findComment-4805461
So for those of you who have seen my car :) *most of you i think* Do you think J Racing could colour match my pink and pearl?? I need to put my new front bar on my baby and I am super paranoid about getting good colour matching!! lol
:D
https://www.sau.com.au/forums/topic/272440-j-racing/page/2/#findComment-4805938
Jerry's shop did my front bar Repair+Paint. The shade was off somewhat so he got his guys to do it all again without any whinge by me. Second time spot on at no additional cost to me. That was my experience :)
https://www.sau.com.au/forums/topic/272440-j-racing/page/2/#findComment-4806073
If my bar just has a simple crack in the front, where it got pushed back into the cooler by a gutter (what a meanie gutter it was! :)) and a few more minor cracks on the underside from driveways etc, would you recommend taking it to Jerry? I wasn't aware JR would be in the business of repairs, figured they only did fitting and fabrication.
what was your damage and how much did it cost you sinista? I've got my own can of paint (which doesn't quite match as the front end of my car is slightly darker than the fuel cap cover I got it matched to lol), do you think they'd use it so I could save a little? obviously I can't expect them to guarantee the paint if I supplied it, but it doesn't bother me much.
https://www.sau.com.au/forums/topic/272440-j-racing/page/2/#findComment-4810547
My lower front bar lip was cracked all the way through 6-8inches long and a few minor abrassions from the dreaded gutters. You can't tell it was ever cracked and they also secured it all the way round properly (not zip ties). Cost to me repaired, preped, re-sprayed and fitted was $400.
JR will do what you ask for. If you want to spray it your self from pressure pack/s then I'm sure he wont have an issue. they should just do the fibre glass repairs. Thats what they do when not fitting full body kits.
Like verything else you get what you pay for and there is good n bad experiences. Even J Racing doesn't have 100% customer satisfaction. That said my experience with J Racing was good.
PS. As said earlier they dont do mechanical and will refer on :)
Edited by Sinista32
https://www.sau.com.au/forums/topic/272440-j-racing/page/2/#findComment-4810603
That's an acceptable price, I think I'll definitely head round there lunchtime Monday and maybe tee something up with them.
Your damage is more or less the same as mine, but yours sounds a little worse from the length of the crack lol :)
https://www.sau.com.au/forums/topic/272440-j-racing/page/2/#findComment-4810615
Got my car back with the bumper repaired from JR today, must say they did a rather acceptable job on it!
Mounted it correctly, and you can hardly tell it was repaired (though naturally if you look closely it's not 100% new looking, few imperfections but who cares)
The only downside of it was the cost, $480 removed, repaired, painted, and refitted. Though considering I walked in Monday to inquire about it and he took it in Tuesday to begin the repairs, can't complain about the turnaround :cool:
https://www.sau.com.au/forums/topic/272440-j-racing/page/2/#findComment-4833972
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
    • So I found this: https://www.efihardware.com/temperature-sensor-voltage-calculator I didn't know what the pullup resistor is. So I thought if I used my table of known values I could estimate it by putting a value into the pullup resistor, and this should line up with the voltages I had measured. Eventually I got this table out of it by using 210ohms as the pullup resistor. 180C 0.232V - Predicted 175C 0.254V - Predicted 170C 0.278V - Predicted 165C 0.305V - Predicted 160C 0.336V - Predicted 155C 0.369V - Predicted 150C 0.407V - Predicted 145C 0.448V - Predicted 140C 0.494V - Predicted 135C 0.545V - Predicted 130C 0.603V - Predicted 125C 0.668V - Predicted 120C 0.740V - Predicted 115C 0.817V - Predicted 110C 0.914V - Predicted 105C 1.023V - Predicted 100C 1.15V 90C 1.42V - Predicted 85C 1.59V 80C 1.74V 75C 1.94V 70C 2.10V 65C 2.33V 60C 2.56V 58C 2.68V 57C 2.70V 56C 2.74V 55C 2.78V 54C 2.80V 50C 2.98V 49C 3.06V 47C 3.18V 45C 3.23V 43C 3.36V 40C 3.51V 37C 3.67V 35C 3.75V 30C 4.00V As before, the formula in HPTuners is here: https://www.hptuners.com/documentation/files/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm?Highlight=defining a transform Specifically: In my case I used 50C and 150C, given the sensor is supposedly for that. Input 1 = 2.98V Output 1 = 50C Input 2 = 0.407V Output 2 = 150C (0.407-2.98) / (150-50) -2.573/100 = -0.02573 2.98/-0.02573 + 47.045 = 50 So the corresponding formula should be: (Input / -0.02573) + 47.045 = Output.   If someone can confirm my math it'd be great. Supposedly you can pick any two pairs of the data to make this formula.
    • Well this shows me the fuel pump relay is inside the base of the drivers A Pillar, and goes into the main power wire, and it connects to the ignition. The alarm is.... in the base of the drivers A Pillar. The issue is that I'm not getting 12v to the pump at ignition which tells me that relay isn't being triggered. AVS told me the immobiliser should be open until the ignition is active. So once ignition is active, the immobiliser relay should be telling that fuel pump relay to close which completes the circuit. But I'm not getting voltage at the relay in the rear triggered by the ECU, which leaves me back at the same assumption that that relay was never connected into the immobiliser. This is what I'm trying to verify, that my assumption is the most likely scenario and I'll go back to the alarm tech yet again that he needs to fix his work.      Here is the alarms wiring diagram, so my assumption is IM3A, IM3B, or both, aren't connected or improper. But this is all sealed up, with black wiring, and loomed
    • Ceste, jak se mas Marek...sorry I only have english keyboard. Are you a fan of Poland's greatest band ever?
