Calder October 10, 2003
NIZPRO BA XR6 TURBO LETS LOOSE with an 11.73 At 125.90 mph.
Nizpro debuted their Acid Rush BA XR6 Turbo sedan at Calder Raceway on October 10, 2003 intent on some ‘shake down’ passes, noting that Nizpro staff were specifically interested in data logging to ensure that whatever changes that may be required, could be easily implemented in the future.
Vehicle modifications consist of Nizpro’s Stage One XRT300 power-up kit (custom powder coated high-flow CNC machined inlet manifold, cast alloy thermostat housing, powder coated cast alloy rocker cover, cast alloy 100mm inlet tube, K&N pod filter, cold air-box, high-flow tube and fin intercooler with lightweight aluminium end tanks, compact dry-cell Odyssey battery and battery box), along with upgraded fuel injectors, and a MoTeC M800 ECU.
For a 4-litre Ford engine that is surprisingly close to stock internally to deliver a potent 426 kilowatts through the wheels on a DynoLogic chassis dynamometer, Nizpro had also to replace the restrictive catalytic converter (in an otherwise factory exhaust system), along with a high-flow fuel pump replacing the factory item.
245mm wide Nitto road/race tyres were also fitted to an otherwise stock vehicle (including the factory turbocharger) that weighed in at 3918 pounds at an independent weight station.
Traction proved a problem, as did the diff ratio that resulted in the Falcon hitting the factory imposed 5700rpm rev limiter by Calder’s 1100-foot mark. However the Nizpro team were quite happy with the information provided by the data logging, and also drove away happy with the knowledge that they had just set the fastest ever time for a BA Falcon Turbo with a respectable 11.73 @ 125.90 mph.
Nizpro’s Simon Gishus stated that having established a base line, and become aware of all potential problems, that he will make specific modifications to ensure the vehicle meets or at least goes close to meeting its potential at the next outing.
Using the traditional Drag Racing formula (speed over mass over distance), it showed that wheel spin and hitting the rev limit had resulted in a loss of approximately 3-4 mph off the terminal speed, with the top end charge indicative of a run perfect 10.6 second pass.
Note: Further information on Nizpro’s Acid Rush sedan, their heavily improved BA XR6 Ute, or on any of the Nizpro XR6 Turbo power up kits; Contact Nizpro on 03-9761 1522.
https://www.sau.com.au/forums/topic/27273-nizpro-xr6t-into-the-11s/
Its good to see that that car is able to make that sort of power with that little development thus far.
Its alos interesting to note that the underated gearbox has lived and shows it potential. it will just be interesting to see just how long it will live.....
If i see an XR6T come at auctions that has been rear ended, then i can see a FORD powered 240Z sitting in my driveway.
Nizpro do good work, friends 200SX engine setup is courtesy fo them and it definitley performs.
Im assuming it was an auto... its scary the potential of some company cars
Awesome!!!
Was only a matter of time before someone put an XR6T into the 11s! Congrats to Nizpro.
Was just reading before in the latest ZOOM that they have their XR6T up to 260rwkw with way more to go.
APS have theirs up to 511hp@fly and SHV have theirs at 400kw at the flywheel..... impressive figures.
This is what separates the Japanese sports cars with the Aussie built performance cars. The Ford XR6 Turbo "Barra" project was undertaken with a very small budget in the hope to boost (no pun intended) some showroom sales against the popular Commodore SS's....
...and this shows, no money was spent on the R&D for a stronger driveline. Ford are STILL using Borg Warner hardware. A T5 manual gearbox, BTR auto's and weak BW 2 pinion diffs. It's great to see that people like Chiptorque, Nizpro, CAPA and others are making impressive numbers on both the dyno and track by defeating the ECU's abuse/protection modes, but it's a shame the weak drivelines let these cars down.
Hahaha. SHV. Shit-House Vehicles. Don't believe a word they say. Driven their purple ute and it's a pile of shit. An NA R32 GTS-t running on 3 cylinders would flog it and that's before you get to the woeful interior quality, horse-and-cart ride, non-existent brakes, etc etc
Originally posted by Sonic
An SP20. It's a daily driver for insurance purposes as a 1966 Skyline ain't the most comfy car to trundle freeways in (damn no air con, p/steer, etc). Seeing as the Skyline bit the dust, the Mazda is also doubling as weekend play-thing
LOL that the car my gfriend has!!
when u gonna own a real car?? :)
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
