hey guys installed mine today
ive got a 6mt so i dont know if any difference yet as i havent even driven the car.
the install was very easy and straight forward. took about 45min all up.
if i were you swap the wires 2 and 8 around as the wire for 8 is a bit longer and will get to the grounding point a bit easier, and 2 is a bit shorter it goes to the battery, and will look a bit neater.
also when you install put all your terminals the right way up, makes it a bit neater and better contact. The wire should be up the top and the terminal flat on the bottom,
Edited by BLISTC
  • Replies 212
Bought this kit with some hesitation as there was no guarantee as how it would fit a 300GT with VQ30DD.
I can now say that I am glad I bought it!!
It did come in handy that I have a 1m cable from another grounding kit available to me though.
I needed it to connect to the battery terminal, replacing wire #2 in the instructions.
Other then that, the front timing cover ground point in step 9 is further away from the plenum side grounding point in step 5 so I just swapped cable lengths around and I ended up with wire #4 unused.
I couldn't find any grounding point bolted to the inner fender wall as describled in step 14 so I looped it back to the -ve battery terminal.
Cable length down to the 5 sp auto tranny is fine. I did not reset the ECU. All bolt lengths are fine, I only changed the bolt at the -ve terminal to a longer one.
The car certainly felt more responsive and 'ready to go' when you accelerate from stand still.
The gear changes are more efficient (earlier) ... semi auto gear changes no longer have that horrible delay.
I did not tell my wife anything as I wanted to see if she would feel any difference herself when she took the car to work yesterday.
She came back and asked me what I did with the car as she was feeling that the car was pulling harder and quicker. hehee ..
Edited by nissan rules
sorry for the crappy pics but here is mine installed from last week:
engine cover on:
engine cover off: (you can also see the motordyne plenum spacer installed in this pic)
also installed the key hole delete on the drivers side.... much cleaner look!
Edited by BLISTC
Kit received today.
once again, thanks for all your efforts in organizing this group buy Fox.
Its much appreciated.
Ur welcome!
and very sorry to MILLOS and Will Power
I couldnt send the kits out 2day bcoz i've been sick for few days. sorry sorry!
ill do it on monday for sure!
glad that it fits!
post up some pics if u can.
Finally managed to get mine and put it on, ended up putting it half on in the dark...
Went for a drive and first impressions are good, VDC seems to improved which is what I was secretly hoping. When going from first to second in a manual flat out with VDC on, as you put it into second it usually feels like you've hit the brakes but it's more mild now, the power comes on quicker after VDC has done it's thing. So hopefully in the wet when accelerating from a standstill it will be improved too, will see how it goes when it rains.
Sort of felt like there was a little bit more go and responsiveness but it could also be a placebo like effect, should become obvious with a bit more driving.
Oh and some of those bolts for stock earthing points on the car are quite soft, don't give them too much torque :down:
Sorry mate, I know I'm being a bother. I'm still alive and kickin', but will only be back in Melbourne on Thursday. Actually I think you can post it anytime now, I now have enough time to pick it up from the post office without fear of them returning to sender!
Edited by siglapian
Sorry mate, I know I'm being a bother. I'm still alive and kickin', but will only be back in Melbourne on Thursday. Actually I think you can post it anytime now, I can always pick it up from the post office!
It's ok mate, i can post it out for you on wed.
i installed a home made jobbie on my M35 today, made a fairly large difference IMO. its nice and smooth, idles well and maybe, only MAYBE, shifts gears faster. im driving down the coast tonight so we will sew how true that is.
not bad for $20 worth of parts, and i didnt even do the gearbox, just the block and manifold. i might ground out the chassis and rough up the factory ground points so it makes better contact
I bought a generic grounding kit from HK (well, bought it 3 years ago for about $50 AUD) and it comprised of 5 cables, but reading this thread, it seems that I am missing 3!!! (in order to be just as good as the US kit)...
I have wired up mine a bit differently though....And I'll take a few pics to show you (after tomorrow's VIC Meet). The only cable I think is an 'essential' is the tranny one, so I am gonna find another wire to do it.
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
