Japan was running an advanced verison of CDMA, last time i checked they was releasing 3G but their own seperate verison of 3G which is larger and handles up to 5gb/sec
If i remember right even when roaming overseas it has to be a compatible network for your phone to pick up the signal.
or if you really want to spend the cash rock up to lawsons and buy a 2000 yen KDDI phone card..
dont expect it to last long when calling to homelines and dont expect teh quality to be at its best.
2000 yen works out to tbe like 25aus
I work for telstra and I get asked these questions quite a lot. Telstras NextG phones and cards CAN work on a 2100 mhz frequency as well as there exclusive 3G850 network.
Telstra is partnered to the JP DOCOMO and Softbank networks in japan.
Call costs are as follows on top of your regular rates.
http://www.telstra.com.au/mobile/internat_...bmit_gsm=Submit
One thing I can suggest before going overseas is to check with your carrier that you have International Roaming activated because a lot of people dont and just assume there phone will work overseas.
I worked for telstra too in the WDCS bris team.. before i left due to management issues..
Well all i can do is warn you of costs..
Was in korea twice last month and 12 days in total, hardly used my phone but didndt turn off data roaming on first trip and got bill today for 45,000 yen..
I've been stung before..over 200,000 yen for a month..
Make sure you turn data roaming off on the iphone!!
i used to work in the Telstra Brisbane project team...April, May, June this year before they ran out of cash and sent me home.
Telstra Management...is that not an oxymoron ? I shouldn't say that should i...they have been paying me $$ for the last 20 years.
Edited by DiRTgarage
None of Australia's networks work in Japan be it prepaid or on a plan, even if they are set to roam globally.
Seriously, where are you getting this information from? :)
I use my Optus mobile every day when I am in Japan and have done so for the past 5 years
The moment I step off the plane and switch my phone on, its connected.
I use my mobile every day when I am in Japan and have done so for the past 5 years.
lol yeah.
Can you tell Optus about how my phone "didn't work"? Maybe I'll get out of my $600 bill for all the not-talking and non-data I used over there last trip... :)
lol yeah.
Good point.
Not sure how I was able to ring you when you were at Gas Panic all those nights when our phones didn't work.
Unless you have some really really important reason to use your phone from Australia in Japan - don't bother.
It would be cheaper to just hire a phone and go to an internet cafe an forward everyone your number. I can't see how people get so attached to their phone that they feel the need to take it with them.
Edited by sleeper_et
    • They are, a good friend of mine bought one to replace his blow factory turbo, running a Toshi Tune reflash. Just use their supplied water/oil lines and you're good to go. At the time, they were like $900 delivered.
    • This is an option for 100% bolt on, the GCG high flow -  https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html Also, I'm pretty sure hypergear does a high flow that is 100% bolt on, it just doesn't make as much power as their bigger high flows.  Even if you get a hypergear turbo that requires you to chance the intake piping, it is a really simple modification. It can be as simple as a piece of silicon hose and you pop a filter on the end. It doesn't have to be some crazy pie cut titanium work of art intake pipe.  If you have the ability to swap the turbo yourself, you would be able to sort the intake piping out.
    • Just as a thought, if it's in neutral, thats your drive line disconnect, not the clutch. Clutch slip at the dyno with pedal fully out, is actually adding a second disconnect. So it's not a clutch issue if you're in neutral. Just a bit of friction dragging the output around while in the air.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
