Hey,
Have had a problem with axle tramp with my car and been trying to fix it but having no luck.
What ive done so far;
- SuperPro SPF2687K RR cross member insert enhancement mount (had to drop whole subframe to install etc)
Still had axle tramp, so put in new suspension;
- Bilstein shocks w/ kingsprings; set at 340mm on rear
Still have axle tramp :P
Does anyone know whats causing the problem?
Any help would be greatly appreciated!
Thanks
https://www.sau.com.au/forums/topic/274697-axle-tramp-in-r32-gtst/
  • Replies 41
btw
10% of the time it’s tyre pressures, the sidewall flexes and releases. Try pumping the tyres up and see if the axle tramp stops and/or gets less.
5% of the time it’s worn subframe bushes, since you have fitted a rear subframe alignment kit (pineapples) I suspect that isn’t the problem in your case.
25% of the time its drive shaft angle, the car is TOO LOW and the angle of the universal joints are winding up the drive shafts. If your car is lower than 345 mm centre of wheel to guard on the rear, then try raising it up.
60% of the time it’s incorrectly matched spring and shock damper rates. The rebound (extension) damping is not sufficient to control the oscillations of the springs. Standard springs with worn shocks get this problem. BRAND NEW aftermarket coil overs get this problem where the spring rate is too high for the shocks to control.
Once you have eliminated 1, 2 and 3, then your problem is #4
:banana: cheers :)
those GIII's arent the same ones i had on when i sold them to u are they? (think thats what i had on)
yeah they the same tyres, they just reached the indicators.
Ive eliminated those 4 options! where is option 5!! (apart from car sitting atm at 340mm instead of 345mm, i doubt 5mm would make it magically disappear...)
Bilstein shocks and springs were supplied as package from suspension place, so they matched perfectly.
So you've got a mate who has seen the rear axles tramping?
Rather than dumping the clutch, have you tried feeding the power ie slightest clutch slip?
Havent got a person to see it, but i definitely feel it when driving. Loud banging in the rear and the gear shifter going nuts haha
I guess ill see if the problem goes away with new tyres, but just wanted to make sure that is the problem...
Thanks
Axle tramp rarely happens while you are driving along. Might I suggest that it could be something in the drive shaft, maybe the centre bearing packing up.
By driving i meant launching in first gear, sorry for the confusion. Was indicating that ive only felt it and havent had a friend spot it from outside the car.
haha wow
have u tried putting ur pressure up to say 50psi? also the only real way to eliminate all the options is to put the height up to around 350, but yeh i doubt that's it, probably not worth the trouble of lifting the car.
with ur subframe bushes, did u install them urself?
haha wow
haha the tyres have served me well, its not like i wear em out cause any sign of traction loss is painful to the car lol
nah i got traction tyres to install them (http://www.tractiontyres.com.au )
Tried to get them to have a look at it, but roads were too wet.
yeh i had terrible axle tramp, would get it taking off in first or just going round corners/round abouts at speed, pineapples didnt work so i got coilovers, no problems since, well, still slight hint at hard launch in first, but still got subframe bushes waiting to go in so should eliminate all together, then my car might be too low, anyways its easy to put up with now
coilovers ftw
coilovers ftw
coilovers come standard in skylines, so a bit more info into what the coilovers actually are might help lol
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
    • 310mm rotors will be avilable from Australia, Japan, and probably a few other places. Nothing for the front can be put on the back.
    • The filter only filters down to a specific size. Add to that, the filter is AFTER the pump. So it means everything starts breaking your pump even if its being filtered out.
