NISMATT Posted January 2, 2011 Share Posted January 2, 2011 Yeah there is no pause for enduros I just left it on overnight. Link to comment https://www.sau.com.au/forums/topic/274780-gt5-is-ready/page/72/#findComment-5608288 Share on other sites More sharing options...
89CAL Posted January 2, 2011 Share Posted January 2, 2011 if theres a 24 hour le-mans or nurburgring event, who would honestly stay up for a full day doing that lol should be a way to save and re-join later Link to comment https://www.sau.com.au/forums/topic/274780-gt5-is-ready/page/72/#findComment-5608328 Share on other sites More sharing options...
Spurdo Posted January 2, 2011 Share Posted January 2, 2011 I got the Toyota minolta 88C-V last night, and added a turbo, 1080hp i think, its fast and pretty good but my god its twitchy, Mind you im playing with a controller and traction control and ASM on so when its oversteering its catching the car and putting fairly bad understeer into it which shoots it straight off if your not careful. Has anyone found a way to fix this? dont be useless. lose the extra turbo.. lose the TCS.. lose the ASM.. even with the controller its not hard to feather the throttle where you need to. dont forget those le mans cars are engineered to only turn properly at high speeds or under throttle, so if you slow down to much and have no throttle on going through a corner you will be absolutely murdering your potential lap time. even on extremely low speed corners you need to be at least partially on the gas through the corner to maintain proper grip and neutral steering the same applies for virtually all le mans & F1 cars Link to comment https://www.sau.com.au/forums/topic/274780-gt5-is-ready/page/72/#findComment-5608467 Share on other sites More sharing options...
89CAL Posted January 2, 2011 Share Posted January 2, 2011 (edited) But more power is always fun Think it's just the asm catching the oversteer and making it unpredictable. Will have a go with it off next time. Need somewhere to clamp my wheel and pedals so I can race properly Edited January 2, 2011 by 89CAL Link to comment https://www.sau.com.au/forums/topic/274780-gt5-is-ready/page/72/#findComment-5608694 Share on other sites More sharing options...
NISMATT Posted January 3, 2011 Share Posted January 3, 2011 Anyone else on here got an X1? If so, what's your best Tsukuba lap? My best so far is 29.6 I got one last night that thing is stupid fast and hard to control with a pad, i did probly 10 laps with it and my best was a very very sloppy 32 something, I need lots of practice just to keep it on the track it is just so fast. Link to comment https://www.sau.com.au/forums/topic/274780-gt5-is-ready/page/72/#findComment-5608916 Share on other sites More sharing options...
sh@un Posted January 3, 2011 Share Posted January 3, 2011 Yes. Yes it is. Definitely a wheel'n'pedal machine. Also got 58.98 at Fuji Link to comment https://www.sau.com.au/forums/topic/274780-gt5-is-ready/page/72/#findComment-5609568 Share on other sites More sharing options...
89CAL Posted January 3, 2011 Share Posted January 3, 2011 whos gonna be the first to post up there top speed in the X1? imagine it can go pretty fast if setup right Link to comment https://www.sau.com.au/forums/topic/274780-gt5-is-ready/page/72/#findComment-5609572 Share on other sites More sharing options...
sh@un Posted January 3, 2011 Share Posted January 3, 2011 I've seen just shy of 480km/h on the chicane-less Mulsanne straight in practice mode just after run-in (1557hp), with downforce set to minimum. Link to comment https://www.sau.com.au/forums/topic/274780-gt5-is-ready/page/72/#findComment-5609811 Share on other sites More sharing options...
mad082 Posted January 3, 2011 Share Posted January 3, 2011 was it still accelerating or was it maxed out? wonder what my veyron could do? i'm guessing not quite as high, but i hit 405 on the daytona back straight before slamming into the wall, lol. Link to comment https://www.sau.com.au/forums/topic/274780-gt5-is-ready/page/72/#findComment-5609934 Share on other sites More sharing options...
sh@un Posted January 4, 2011 Share Posted January 4, 2011 accelerating very slowly- the bumps knock it around quite badly, and it's very twitchy with the d.f set to minimum. also realized the toe-angles were set to - and +1 front and rear standard, which may have scrubbed some speed. car makes less power now so there's no point trying again it's geared to do 507 (which you can't change), you should be able to get 490 or more if you cruise up behind a Le Mans car 3/4 of the way down the straight and get an aero tow Link to comment https://www.sau.com.au/forums/topic/274780-gt5-is-ready/page/72/#findComment-5609975 Share on other sites More sharing options...
NISMATT Posted January 4, 2011 Share Posted January 4, 2011 (edited) Ive got it up to 499 with a tow at le mans. Edit: Just had another crack at it and it redlines at 499 with aero turned to minimum. Edited January 4, 2011 by NISMATT Link to comment https://www.sau.com.au/forums/topic/274780-gt5-is-ready/page/72/#findComment-5609995 Share on other sites More sharing options...
sh@un Posted January 4, 2011 Share Posted January 4, 2011 oh yeah- the Bug's managed 429 clicks at La Sarthe Link to comment https://www.sau.com.au/forums/topic/274780-gt5-is-ready/page/72/#findComment-5609999 Share on other sites More sharing options...
sh@un Posted January 4, 2011 Share Posted January 4, 2011 Ive got it up to 499 with a tow at le mans. style Link to comment https://www.sau.com.au/forums/topic/274780-gt5-is-ready/page/72/#findComment-5610004 Share on other sites More sharing options...
barraspalding Posted January 4, 2011 Share Posted January 4, 2011 i've not dragged the wheel out n cranked this game in a few weeks... will get bak into it one day Link to comment https://www.sau.com.au/forums/topic/274780-gt5-is-ready/page/72/#findComment-5610071 Share on other sites More sharing options...
89CAL Posted January 4, 2011 Share Posted January 4, 2011 I think I only managed 420 or so in the veyron, but that was just a practice run to see if it would hit 400 with no other cars on the track. got my 111 feet per second or whatever it is lol so i was happy. Been hitting B-spec lately. My hot headed driver is getting quite good at level 12. Nowhere near as much frustration Link to comment https://www.sau.com.au/forums/topic/274780-gt5-is-ready/page/72/#findComment-5610133 Share on other sites More sharing options...
NISMATT Posted January 4, 2011 Share Posted January 4, 2011 Anyone else got funny B spec names? I just hired 3 more called F Massa. S Oneal and S Bullock. Cant hurt to have a chick driving my X1. Link to comment https://www.sau.com.au/forums/topic/274780-gt5-is-ready/page/72/#findComment-5610205 Share on other sites More sharing options...
Spurdo Posted January 4, 2011 Share Posted January 4, 2011 farkk it.. old ps3 packed up good and proper last week. just went and bought a new slimline. how lucky was i to backup my gt5 data about 2mins before it broke.. although all my other game saves are down the tube.. ffs sony needs to sort their shit out and come up with a way to transfer saves off the old hdd Link to comment https://www.sau.com.au/forums/topic/274780-gt5-is-ready/page/72/#findComment-5610317 Share on other sites More sharing options...
iamhe77 Posted January 4, 2011 Share Posted January 4, 2011 farkk it.. old ps3 packed up good and proper last week. just went and bought a new slimline. how lucky was i to backup my gt5 data about 2mins before it broke.. although all my other game saves are down the tube.. ffs sony needs to sort their shit out and come up with a way to transfer saves off the old hdd erm, doesn't the "backup" utility do this? I upgraded to a 500GB HDD and all my save games went across no worries. Just needed to re-sync the trophies. Link to comment https://www.sau.com.au/forums/topic/274780-gt5-is-ready/page/72/#findComment-5610368 Share on other sites More sharing options...
Spurdo Posted January 4, 2011 Share Posted January 4, 2011 erm, doesn't the "backup" utility do this? I upgraded to a 500GB HDD and all my save games went across no worries. Just needed to re-sync the trophies. i didnt upgrade, my console died. making it impossible to get access to my saves. one time i tried the backup utility it tried to backup everything on the drive, movies, music, the lot. didnt have a flash drive big enough for it. i only need a backup of saves but it doesnt let you do that Link to comment https://www.sau.com.au/forums/topic/274780-gt5-is-ready/page/72/#findComment-5610403 Share on other sites More sharing options...
iamhe77 Posted January 4, 2011 Share Posted January 4, 2011 i didnt upgrade, my console died. making it impossible to get access to my saves. one time i tried the backup utility it tried to backup everything on the drive, movies, music, the lot. didnt have a flash drive big enough for it. i only need a backup of saves but it doesnt let you do that I know, but you could still remove the HDD from the stuffed PS3, put it in the new PS3, perform the backup to an external HDD then put the original HDD back in the new PS3 and "restore" Link to comment https://www.sau.com.au/forums/topic/274780-gt5-is-ready/page/72/#findComment-5610444 Share on other sites More sharing options...
