Hey Guys,
I've just had my motor rebuild because i spun a bearing.
the engine had all these parts new: pistons, bearings, crank, water pump, sump baffle.
head also has been recond, thicker head gasket, oil restrictor to the head.
my O2 sensor had been damaged when my rear turbo blew 1 month before the motor went (been replaced with 2860-5's), and the new sensors havent come in yet, but the mechanic said that they'll be there when the car needs a first service after 1000kms.
so i've been driving around with the sensors not plugged in, he told me that its okay because the ecu goes into safety mode? plus i am not boosting the car, keeping it under 4000rpm and trying to keep on 0 boost which is hard.
the car is really responsive down low, and runs better than it ever has, just wondering whether anyone else on here has done the same thing? and if they have seen any issues?
cheers guys!
yes you can. i drove round with it unplugged in my pulsar for ages. even stuck a wideband up the tailpipe to check AFR's. instead of running around 15:1 you will be running 11 or 12:1. so your fuel economy shouldn't be excessively more because when you floor it even with the o2 sensor plugged it ignores the o2 sensors.
can you? yes. should you? no. well not with a stock ecu and a new engine.
at idle and on cruise the car will be running excessively rich. so make sure you do not leave the car idling or at steady state (small-moderate throttle openings, low load, low rpm) cruising for any prolonged period of time. you should be doing that anyway but with it being all the more rich the last think you want is all that fuel washing down the bores.
yeah i was told not to let it idle for too long, also to not sit at the same low rev's for too long, just keep slowly accelerating and backing off.
also one thing i have noticed, that its boosting at lower rev's than it used to. so really to keep it completely off boost i have to shift @ 3,000 rpm but if i got to 4,000 rpm it will have a little bit of boost, maybe from guessing on the guage 3-4psi.
does Boost really do much damage when running in an engine? i'm not wanting to thrash the car, but when you're putting a little bit of load on the car the boost does creep up.
cheers for any help
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
