Oh whoops... LOL, ignore me... Brainfart moment... :P
I still expect a 3RD gear limiter bashing skid at Texi...
will give it the beans repeatedly, disconnecting the entire exhaust from the headers doesn't count as a screamer pipe right?
by the way beaker I bought a "92" vh45 ecu so i can nisstune. but it won't arrive in time :mad: . and what do you want in your package I'm sending?
got a new three core, triple pass, crossflow, copper radiator and new fan mounts that should keep it cooler. the radiator hoses are no longer 5mm away from the alternator. yay.
will have to test it at texi. pics to come.
  • 2 months later...
long time no post...well here's whats new, nothing other than finally got a nistune from unique autosports. the result?
30 kw gain at wheels. something tells me nissan undertuned these alittle.
  • 3 weeks later...
is it bad that the 79 two two door corolla i bought off a work mate had 30 degrees timing when GTRsean and I did a quick tune up today? althrough it does explain the noises it was making.......and why it looks like it head gasket is on the way out.
somehow i managed to be talked into a twin side draft weber manifold and carbies, and the plan is to put the biggest cam the stock rockers will allow. who knew spool made forged rods for them. it will sound wicked, weather it goes anywhere in hurry is up to debate. it was supposed to be a daily, so much for that idea.
It's a 'cool' daily!
So another engine I will be doing.
It will have the following:
.5mm over pistons
spool h beam rods
4K block decked, bored and honed
crank balanced
flywheel lightened
sump modified
oil pump shimmed
3K recoed head with 4K style stem seals
some sort of solid regrind cam with 260-270deg and .400" lift
port match and cleanup.
rollmaster double row timing chain
4-2-1 headers
redline dual side draft carby setup
electronic dizzy
I think that is it....
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
