Oh whoops... LOL, ignore me... Brainfart moment... :P
I still expect a 3RD gear limiter bashing skid at Texi...
will give it the beans repeatedly, disconnecting the entire exhaust from the headers doesn't count as a screamer pipe right?
by the way beaker I bought a "92" vh45 ecu so i can nisstune. but it won't arrive in time :mad: . and what do you want in your package I'm sending?
got a new three core, triple pass, crossflow, copper radiator and new fan mounts that should keep it cooler. the radiator hoses are no longer 5mm away from the alternator. yay.
will have to test it at texi. pics to come.
  • 2 months later...
long time no post...well here's whats new, nothing other than finally got a nistune from unique autosports. the result?
30 kw gain at wheels. something tells me nissan undertuned these alittle.
  • 3 weeks later...
is it bad that the 79 two two door corolla i bought off a work mate had 30 degrees timing when GTRsean and I did a quick tune up today? althrough it does explain the noises it was making.......and why it looks like it head gasket is on the way out.
somehow i managed to be talked into a twin side draft weber manifold and carbies, and the plan is to put the biggest cam the stock rockers will allow. who knew spool made forged rods for them. it will sound wicked, weather it goes anywhere in hurry is up to debate. it was supposed to be a daily, so much for that idea.
It's a 'cool' daily!
So another engine I will be doing.
It will have the following:
.5mm over pistons
spool h beam rods
4K block decked, bored and honed
crank balanced
flywheel lightened
sump modified
oil pump shimmed
3K recoed head with 4K style stem seals
some sort of solid regrind cam with 260-270deg and .400" lift
port match and cleanup.
rollmaster double row timing chain
4-2-1 headers
redline dual side draft carby setup
electronic dizzy
I think that is it....
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
