  • Replies 372
Posted Images
Im sure if Cerbera dosnt come first we will here such excuses like I only had 1 thong on, the go kart was missfiring , the track was wet on his line, Me penis is sore from the bee sting, my team mate slowed us down and so on.
its hear not here you uneducated greese monkey!!!
in other news...
sloth performance who have been working full time on the sloth racing entry kart for the past months have finally given up... it's still making half the power it once did with no signs of improvement. some have suggested taking tha machine to a karting mechanic only to realise that sloth performance is meant to specialise in karts
in other news...
Rumour has it Marbles from No Knickers racing is excited at driving the karts as they have more power n torque then the shitter rb20 32 he has ;)
Listen here turds....
you are all pissing in the wind!
Team RamRod and Team Sofa King Fast are the leading teams....!
But I do laugh at the attempt at humour and abuse
You are all HATS!
You are all HATS!
What about team pit on last lap , reckon they have a chance Mike :O
Bard dont make drop gtr diff on ya foot before the race :blink:
Team "From Behind" will bend each one of you pricks over our Kart, and we'll shove our winners trophy up your ass :(
Its clear to me that you have never held a 1st place trophy , because thats not what you do with them :mellow:
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
