well if they have to meet emissions targets...go for it!
At the end of the day, you have to have it's big brother to get one which is a smart idea. Makes it easy to say 'I drive an AM' and I think the resale will actually be pretty good because everyone that can't afford a proper AM will look for these on the 2nd hand market.
Just please don't make it look ugly which it does so far. Turbo it.
I really don't think it looks that bad. You need to remember this is a car built for fuel economy, safety and being aimed at the low cost small car market. Compared to other cars in the market it will be competitive against such as the Echo, Getz, Fiesta etc i think it outclasses them in terms of looks.
Although I don't particularly agree with the fact that in order to buy one, you need to already own an aston martin. I think thats a bad move
Edited by Baz
i guess there's a market for it...like any business they are taking the opportunity to make a $$$$$.
Speaking of opportunities to make $$$$, have you guys started filming home videos yet? I'll be happy to direct...
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
