No not your motor's dyno graph Paul, just cam duration change to Marko's one :cool:
lol...interesting comparison though...just shows a basic 26...is just as good as a big $$ 30...and makes earlier torque but doesn't hold on as long. The graphs are very similar with Marko's pipping mine by 0.1KW
I thought you may have been hinting at your engine...don't you run smaller cams Steve ?
Edited by DiRTgarage
  • Replies 477
Thats right, I used 270IN and EX with 10.25mm for the current one. But the cams were never dialled in during the tune as we were pressed for time, that aside it would be great if someone could overlay Marko's graph and this graph;
Note this is using the same size turbos (im pretty sure marko has the .6 -10's meaning 400hp each, im on HKSGTRS's) and my head is only cleaned up, its not "ported"
Down low its pretty much the same, but look at the midrange and up top, also lower boost
stevo, if i switched them there is labour + another tune = $
your above graph is based on a 2 wheel dyno whereas mine is a 4 wheel dyno which may also change the results (i.e. jim @ crd advised my power level on 2 wheels on his dyno is 445rwkw)
the bigger the better with rb30's as i was informed!
to be fair yours still has a little way to go though Marko and i was running more boost (27psi)...why do you think im building one.
can't wait to see what it does with my head, turbo and plenunm on one drinking methanol at 35psi. :P
a direct comparison between my current bottom end and the 30 after running mine in with pump shall be interesting...my turbo should really come into its own. I feel that 30 bottom ends do have their application, but im far from convinced they are the be all and end all.
i spent over 20k building my engine BUT i sold off all of my other bits from the rb26, end of the day the whole thing cost me approx 13k (includes tuning cost @ $1500)
best 13k ive spent to date :P
As Bakes says...if it makes you happy its a bargain.
how much do you get back from Wayne Swan for the engine ?
no need. :) you can see if it peaks at 8500 that each line is 3,4,5,6,7,8000rpm. :ninja:
it's interesting that my 26 with headwork, small cams and GT-SS made 160kw @ 4,000 vs 150kw on the 30 with GTRS, and at 4,400rpm mine was 210kw vs 180kw for your 30. at 5,000rpm i'm making 250kw and you have 230kw. at 5,600 I have 275kw and you are now just overtaking me with 290kw (also getting very near your peak torque). and then at 6,000rpm I have just 290kw you have 330kw and from 6,000rpm to 8,000rpm you run away with the bigger turbos and make another 100kw.
it's interesting though that the 3 litre doesn't make the GT-RS turbos as responsive as people make out. there is still a lag price to pay when you see that a little ol 2.6 with the baby GT-SS are about even with it up to 6,000rpm. having said that mine was only running about 17 or 18psi at the time as I was being a bit conservative, it's now running 23psi in the hands of it's new owner and I think with that more boost, and it coming on sooner it would give the RB30/GT-RS combo a good fight up to 6,000rpm and would probably feel more responsive/torqueier down low on the street. the top end power can't be denied though!!! and when it comes down to it they are two different dynos so it's hard to really get any truth from it, but it is still interesting. I've no doubt though on the whole the 30/RS combo is faster. but i'm not 100% sure which would be the better street car/hills thrasher... ?
no need. :ninja: you can see if it peaks at 8500 that each line is 3,4,5,6,7,8000rpm. :ninja:
Well see that's i would think myself at first glance... However i don't want to assume just yet because as it was asked earlier...
Have I got it right, max torque is around 4,250 rpm and max horsepower is around 6,100 rpm and it makes less than 50 rwkw at 3,000 rpm? Or is my maths totally screwed up?
So 3 of us are thinking that is how the axis is, so indeed only making 50rwkw @ 3,000rpm (by what we think)
However Marko then came along and said...
your calculations are not right, would be if it was a rgv250
Which basically says none of us are correct in our assumption of the bottom axis
So that would almost certainly mean its not the scale we are thinking :ninja:
Hence I'm trying to find out by actually getting the bottom axis to be sure :)
i'll post another graph tonight from my other pc which includes the km/h axis (it is from 0-200km/h)
i had an rb26 with gtss's & i can tell you that the difference in torque is massive between the rb26/gtss v's rb30/-10s :)
chalk & cheese
well he himself said it was revv'd to 8,5000 not 9,000rpm. so assuming he's telling the truth then peak TORQUE is about 6,500rpm and peak power is about 8,000rpm and held to the 8,500rpm limit. not sure where gary got the 4,250rpm for peak torque if it's being revv'd to 8,500rpm?!
this well considering i pulled an 11.1 @ 129mph with my rb26/gtss setup which had 312awkw...this setup will smash a 10!
agree with that, but not all RB26/GT-SS set-ups are the same.... :)
    • We have a huge update coming in the next few months, version 5 of Invision will be released. I'm holding off any changes until after this change as I'm not sure what features will be removed or introduced.
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
