Did some tuning over the weekend. sorted a boost leak that made a bad noise at 17+ psi. After going over the logs from friday night, the car makes 16psi at 4000rpm. I've upped the boost to 19psi, but havn't done and tuning or logging on it yet.
Damo wasn't able to drive the car for more tuning today, so i knocked up a heatshield to keep the inlet cool
Should have the tuning finished this week, and then it's off to it's first supersprint on sunday
Well the car got it's first run on the track this weekend. I was pretty happy with how it went, only problem was a pertty bad shudder though the steering wheel after the brakes heated up, i'm hoping it's just the pads going through there first heat cycle. They are Endless ccx that came with the calipers, and from a quick glance at the net, other people have had the same problem with the stoptech/ccx combo. I recon I'll put some hawks into them.
The car is very easy to drive, and we only just touched the surface of the shock tuning, the rebound is still at full soft. The car was still getting .5 sec a lap faster with each change. Ended up the day with a 62.8. Always fun when people come and basicly call you a lier when you tell them it's a standard wrecker rb20, with a rb20 highflow.
I will put some video on the tubes tonight, and upload some of Damo's artsy pics
the washer bottle is the temp catch tank.
no idea on power, only dyno it's been near is the arse dyno, asit was all road tuned. It's running 16psi boost at the moment...might need to turn it up some more though
Don't you just love it. Its a good feeling when you exceed peoples expectations with a humble, maligned RB20 :)
Re the brakes , CCX are good things but perhaps they are too hard on rotors. I have used only one set and loved them but they did seem to have an appetite for rotors with regards to shudder and cracking. I will be trialling the PFC 06 pads with the Stoptechs and 343mm rotors. I am really happy with how they have all come up. I will try and get a set of DS3000s to trial back to back with the PFC06 before they get too worn
Any Vids/pics yet?
Nice vid. How fast was your GTR around SP?
Best I got was a 60.9. But as you can see it's all about HP, and the GT-R was up 10-15km/h at the end of the straights, and cause of the brake problem was a braking 35-50m earlier than a was in the GT-R.
In the Targa N1 the last time I drive it, it was in 2009 trim, and I got a 60.3. But 2010 trim was about 50rwkw more.
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
