this post says its a standard bottom end, pistons in the previous pictures of the bottom end look fairly standard and arent dome tops as i would expect in a high comp bottom end build.
no signs of a VCT mod that i can see (your "b-cam" was discussed before)
pictures of the head look to me like it has had a reasonable whack of meat taken off the bottom of it. if the car is running corn juice or race fuel only im thinking even higher than 10:1 11-12?
if thats not it at the moment im not sure what else it could be to give that big of a change
It used to be a 26 head... ??
First and last hot lap for the new engine, seems i have a high flow #2 piston :(
It was a rubbish lap too, I left the buggered tyres from Targa on the rear, as it always used to push. But it appears i've fixed the front end grip.
Geebuz Benny that's rotten news buddy! WTF happened? :(
And yeah, if that speed is reading true, you've got an outright contendeer there! The gearing is way different to mine too. I'm going to assume there's a technical setup glitch there somewhere?
Top speed was a big surprise. It's done via GPS, and is was getting data off 10 sats at the time. I'm pretty comfident it's accurate, the rpm vs gear calculates pretty close, and the lap time would indicate a good top speed since i stuffed the first corner so bad.
i'll have the engine out and head off tonight, but it looks like it might have been a clogged injector, as we test spreyed it at the track, and it didn't mist properly. #1 injector looked heaps better. I've been over the logs, and lambda was .71 at full noise, fuel pressure was 65psi, EGT was ~750 deg, and I couldn't hear it pinging (i've watched the video heaps of times to listen to it too). So i'm confused on what caused it.
What gearing do you have Ben? mine is a std RB20 box, and a std diff gearset (4.3 i think). unless a 4.11 got in there before I got it
I have stock 20 box, and I assume stock gears (4:3?). Yours looks a lot like 32GTR gearing, so maybe 4:11.
There's no doubt your thing looks to have some serious stonk :) Shame about the pesky injector :(
1:1 4th gear at approx 7,800 rpm shift I get 190klm/h.
http://www.youtube.com/user/BennyTheWoo?feature=mhee#p/u/15/M9L49eCE7RU
GPS so accurate hey? Fark me! I come on to the straight at PI at 170-80km/h and I hit 233km/h going downhill, on a very long straight with a short braking area as turn 1 is ~180k/h. Yet you hit the same speed on that lap! I need to pull my finger out and get the Cossie registered so the R32 can go corn juice and more boost :)
comparing data from targa to bens day at the track the extra torque is what helps it punch a whole thought the air. during targa with the not so grate engine it would just about go backwards in 5th. they seem to have a fair jump from 4th to 5th.
what ben has also not mentioned was the massive tail wind he had. haha
it wasnt a grate day for either of us. but my blown clutch is a lot easer than the engine swap, again!
The tail wind at symmons is worth some speed.
Got the engine open tonight. Looks like all the damage was caused by the tip of the spark plug that was missing. piston is full of dents the size of the missing piece, and the side is smashed out of the exhaust valve. Still need to work out why the tip came off
    • Absolutely could be. I collected data logs from when the O2 sensor was still out and also after I had replaced it so will try to compare them. Pretty confident that the affect is lowered with the new sensor, will check logs at the same RPMs/conditions.
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
