Haha yeah i'm serious i got the receipt for it, bloody ridiculous. Cheers for the link NXTIME ill check it out tomorrow, also Marko R1 where did you purchase yours from.
www.purplepig.com.au
industrial suppliers
Man, this is what i want my dream skyline to be like; hand built, fast as... well anything, and an r32 :D
I'm looking forward to seeing this finished man, the closest thing i'm doing to working on a car is finding average audio parts for the incoming pulsar :)
Hope everything goes well bro. It had better do under 10's :( haha
Hi Guys
Finally Figured out how to put pictures up properly so here's a heap more:
PS If it doesn't do a 10 sec pass straight up, ill burn it to the ground hahaha!!!!
FRONT BUMPER GONNA LOOK SOMETHING LIKE THIS:
TBO CARBON FIBRE DOORS 5.9KG EACH
CARBON FIBRE BOOT
CARBON DOORS FITTED TO CAR
BRIDE ZETA III LOW MAX WITH 6 POINT TAKATA HARNESS FOR DRIVER AND 4 POINT FOR PASSENGER
CARBON FIBRE DASH IN CONSTRUCTION
SUPERIOR AUTO CREATIVE CARBON INTERIOR GOODIES
CENTER CONSOLE PAINTED 2 PAC BLACK WITH CARBON TRIMS
WORKS BELL STEERING WHEEL AND QUICK RELEASE SETUP
ROLL CAGE PAINTED
PWR CROSS FLOW RADIATOR 55MM CORE
PWR PLUS THERMO
MASSIVE FUEL SYSTEM
Got the carbon goodies from RHD Japan, yeah the boot could be getting a custom drag wing mounted to it, as we are gonna run the factory panels for street trim (cause of the cops and want sleeper look) and use all the carbon goodies for serious race events.
Hi Guys
CARBON FIBRE BOOT
ROLL CAGE PAINTED
PWR PLUS THERMO
MASSIVE FUEL SYSTEM
Very Nice indeed!!!
Hi Guys Just an Update..
Waiting on turbo to get Adel wiggins Ferral welded on, also had to send the Throttle body back to Hypertune as they will dissasemble it and weld the 4" Wiggins Ferral on for us and reassemble etc. I finished wiring the 5 fuel pumps up today on seperate relays all controlled by there own pilot switchs in the cab.
Hoping to Order the rest of the -4 braid soon to finish off boost lines and other little fiddly jobs.. my dad will be speaking with Mark Jacobson this monday in brissy, hopefully to arange a rough date for when the car will be heading down that way to get run in and tuned.
If anyones looking at ordering Adel Wiggins clamps I have researched everyone under the sun.. ended up dealing with Gas Motorsports, the clamps are rediculously expensive but boy do look shit hot. haha
Hey mate nice build so far. But it looks to me as though you have a lot of the rear of your radiator core blocked off with the aliminium plate might pay to make some new brackets as there isnt much point having such a big core if the airflow cant get thru there because such a large area is blocked off. And just wondering why 5 fuel pumps ?.
Did you guys solid mount the engine to the chassis? The wiggins clamps don't have any flex, so if your motor moves and the pipe work is secured down to the chassis/body- somthing is going to give and it aint gonna be the wiggins clamps.
GL
Justin.
GL
Justin.
Edited by AD4M
Hi Guys just some reply's to ur questions..
first one to you dazmo, yes the back of the radiator is completely covered, this is the new design from PWR used on the Aston Martins Cars.. has a thermo fan and 3 rubber flaps which we havent put in yet.. when the car is iddling the flaps close and draw more air through the radiator.. but when driving along the flaps open up the air is alowed to pass through.
Five fuel pumps, haha yes one is for a lift pump to the SARD 5L surge tank, and four pumps for when the car runs on methanol. Our alternator has been rewound to 120Amps from the standard 90Amps because each pump draws 13Amps and CDI will pack a punch too.
second to Xrated, we have welded our engine mounts solid as a rock.. we didnt use wiggins clamps on the intercooler and stayed with normal silicon hose for flex there if needed.
Hi Guys
Here's an update for you's:
Progress so far, most of the wiring is done, the engine has been put in for the very last time and everything bolted in now and is there for good. The 1.25 inch Adel Wiggins Clamps have turned up for the radiator, so that will be getting fabricated soon. The New brake rotors have also turned up so that will be getting put together as well.
As the pictures will show the interior trim is getting put in (What is left of it) so its starting to look like something!!!!
Cheers
Benny
    • Kittens in first to claim dominance of the residence, then puppies later From past experience, the other way around can be problematic to say the least  Those weird "Dobby looking"  little kittens are not cheap....LOL
    • At least yours have parkour down pat. One of mine will still trip over his own shadow and fall over... He's a special type of cat... Ha ha ha
    • The question then becomes - was there any fluid coming from that hole before you did the rebuild ?    You may not have noticed, of course.   Depending on how you did the rebuild, the possibility has to be considered that somehow (cleaning ?)  fluid entered that hole and is now being 'forced'  out by small movements of the proportioning valve.   From the factory, there's actually a small rubber plug in that hole but with age and under-bonnet heat it's quite common for it to 'go missing'.  That rubber plug is designed to allow the venting process but also to prevent 'stuff' getting to the area (prevent corrosion, etc).   The plug is also not available as a spare part AFAIA. Personally I wouldn't race and buy a new master just yet but keep an eye on the area to see if the 'leak' continues.   If you're concerned about brake fluid damaging nearby paintwork, cable tie a piece of suitable absorbant material over the hole and remove/monitor occasionally.    Operation of the proportioning valve and the brake master itself won't be affected, but also keep an eye on brake fluid level, of course. In terms of a new master, the genuine part is getting expensive, unfortunately.  Amayama is showing AUD900+.   I was searching recently and there's an aftermarket part available from Japan made by 'Parts Assist': https://zenmarket.jp/en/yahoo.aspx?q=BNR32%2bBM50&p=1 Whether it's any good I have no idea, although in my experience Japanese aftermarket stuff is pretty good quality-wise.   The above site allows overseas buyers to purchase stuff more easily from Japan but there are fees and shipping costs, of course.   The original Japanese seller page is here: https://auctions.yahoo.co.jp/jp/auction/p1197401228 Copper/Nickel is fine but I still prefer bundy tube and it's also cheaper.
    • Your chihuahuas look weird!
