  • 4 weeks later...
For those that are curious, this months edition of PI (Performance Imports) is in stores now if you want to see some awesome pic's of it, cheersthumbsup.gif
Just picked up my copy :) I will be flicking through it soon :) You have made me want Bride seats now :)
Hi Guys,
Our Car is on the Front cover of HPI Mag this Month, Issue No. 142, Very good article from the guys at HPI.
Just an update on the car, Have been building a 6mm thick Scatter shield around the Bell housing on the GTR as any GTR owner would know there is very minimal room around the top of the gearbox once its in the car. Somehow we persisted for weeks to make this Guard. Just waiting for a Strain guage to turn up, and than we should be putting the engine back in the car over the christmas period. The Car will be going back to Mark Jacobson at Godzilla Motorsport for a check up and retune the car at 35psi around the end of Jan-Feb.
Here is the REG 4.9.7 out of the 2011/2012 ANDRA rulebook:- The use of a properly constructed steel, aluminium with steel or titanium lining, titanium bell-housing is mandatory for clutch equipped vehicles in top fuel, funny car, top alcohol, top doorslammer, Pro stock, and competition eliminator. All other clutch equipped cars running quicker than 11.00 (1/4 mile) / 7.00 seconds (1/8 mile) are required to use a steel, aluminium with steel or titanium lining, or titanium bell-housing or shield. Bellhousings certified to SFI6.1, 6.2, 6.3, will be acceptable providing the SFI spec matches the clutch assembly used. A totally Enclosing 360 Degree, one-piece bell housing must be formed or fabricated entirely from 6mm (1/4 inch) steel plate and attached directly to the rear of the engine. Where used, Flywheel shields must be constructed so they completely surround the clutch failure. The shield should be constructed from 6mm (1/4 inch) steel plate, and extend forward to a point at least 25mm (1 Inch) ahead of the flywheel, and 25mm (1inch) to the rear of the clutch and pressure plate. Shields must not be bolted to the bell housing and should attach securely to the frame/chassis. all the shields or bellhousings must be removed from the vehicle for checking during the technical inspection. An engine support strap made of steel or aircraft cable (chain not accepted) capable of supporting the rear of the engine in case of bell housing failure is required on all cars, unless it is evident that the headers or frame rails will prevent the engine from dropping.
Will upload some photos of the Scatter shield next week, it also added about 15KG of weight to the car,
I'm surprised that after 20odd years no-one has made an SFI approved bell housing for these yet.
Either way I am so glad my car is Auto because mine has even less room that the skyline around the bell housing...not that It will be running quicker than 11.00 for a while
Hi Guys,
Got some gear for sale if anyone is interested. All the prices are only for the items, postage is extra.
This is a 12/24volt Pre Lube pump with -12 inlet and outlet, can pump up to 60PSI. We used it as a safety backup if we lost our dry sump pump belt we had the pump kick in off a pressure switch. These pumps are $600 brand new and this one was used once, and we changed our setup due to new ANDRA rules. Im asking $400
Morroso Breather Tank with -12 Male JIC fitting. $100
Proflow -12 Oil or fuel 100micron screen. was used in the prelube oil setup. $75
Peterson -16 Oil screen 100micron, Rocket Ind wants $170 for a new one. This is used once aswell im asking $100
3 Gallon Peterson Dry sump tank, Dual Scavange inlet, Added extra -12 Male JIC at the bottem welded in. In Very good condition, Rocket industries is asking $815 with the two clamps.
Im asking $600.
HKS turbo shield $50
Stillway Shifter used once, reason for selling it is a short shifter and is to hard to change gear with a straight cut dog box, but works really good in its concept. Would be ideal in a streeter/drag car. The going price is $600 it took quite a few months to source this item.
Custom made fitting for the dry sump tank, -12 O ring port to -16 female JIC for the Screen return. $50
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
