  • 4 weeks later...
Hi to all
Another update for you's, so far this month we have managed to order all the remaining bits we need to finish the interior with. Starting work on the carbon interior in the next few weeks. Rollcage is completed and only underneath the car needs tac welding.
A Quick list of parts on the way:
OKUYAMA Carbing Pedal Set
OKUYAMA Carbing Driver Foot Rest
Superior Auto Creative Carbon-Look Shift Boot
Superior Auto Creative Carbon-Look Center Console Cover
Superior Auto Creative Black Carbon Room Mirror Slim
Superior Front Door Panel Kit BNR32 R32 Black Carbon and Perforated Black
Works Bell Rapfix Campaign Kit (Limited)
Superior Auto Creative Carbon-Look Side-Brake Boot and Grip Cover Set
Sun Line Racing Steering Adapter
Cusco Adjustable Rear Upper Arm Links
Cusco Adjustable Rear Upper Arms
ARC Columnar Type Mirror Finish Titan Shift Knob with ARC Logo
Trust Greddy Tie Rod Angle Adjuster Tie Rod
OKUYAMA Carbing Passenger Plate
TAKATA Crotch Strap for 6-Point Conversion
RAYS Volk Racing Duralumin Lock Nut Set Red
Bride Zeta III Low Max Seats x2
Takata 4 Point Harness x2
UAS Front Top Camber Arms
UAS Diff Bushes
UAS Rear Subframe Bushes
UAS Rear Subframe Spacers
Plus many more things!!!
This is looking like its going to be awesome when its done. Nice choice on all the parts.
Got any photos showing the bulk of the Roll cage setup? And are the diffusers installed yet? If so i'd love to see how they ended up.
Cant wait to see more.
Luke
  • 1 month later...
With all do respect.Where do u get ur money from its taken me 3 yrs of hard work n doin it all myself n mine will only have round 400kws at the when its tuned i respect u boys but im strugglin to get mine to 400kws.
I think it comes down to sacrifice more than anything, i give up a lot of things to do these mods and work hard, plus its not just an individual project either, the costs are split evenly between me and dad so that helps. Also if you do the majority of the work yourself, you can save thousand $$$$, i would hate to know how much it would have cost to do that carbon dash by a workshop.
Update pics coming soon, we have nearly all the parts collected in a room and going to pick up the engine & gearbox in a few weeks, can't wait so excited.
Heres a quick peek at the dash!!
Hello everyone, just an update on the car. Went down to Godzilla Motorsport in Brisbane to pick up our Engine from Mark. Very happy with it, i have some pictures and some specs on the internals.
JUN 2.7 Stroker
JUN 295 degree Cams
Oversized Valvesm, all head gear is Tomei
Stage 3 Port Job,
NPC Twin plate Clutch
ATI Harmonic Balancer
Custom Dry Sump Setup
ARE 150mm Intercooler
Hypertune Plenum and Throttle body.
PPG Dog Box With the works
+ much more
wait on...just looked at the pics.
does that say T62 or 51? hard to see in the shots
its a 62.
Jun do not produce a 295 deg camshaft off the shelf...is it a special order custon grind?
What retainers are you using?
-Turbo is a HKS T62R
-Yes Jun do make a Custom 295 Cam, they cost a fair bit.
-The Retainers are Tomei as the springs are Tomei Type C
-The dash is a standard dash with carbon overlay.
Yeah you would be correct, that is Marks old intercooler, it flows 5 degrees cooler than the trust drag cooler and has made up to 1400hp with so its well and truly up to the task.
    • Clutch is a spec brand, new clutch system,( PP, flywheel, friction disc, etc. pull type) installed 100 miles ago, with no problems.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
