Hello,
I have just been told that I have to take out my Microtech ecu (cops) and was looking at the nistune option. What my question is are they a good option to go for knowing that i will be checked for to see if my ecu looks stock. Is there many of them being used. my car is a r33 s2 (auto)
Mods so far are FMIC, full exhaust, splitfire coils, did have a Eboost2 boost controller but also had to be removed & a Hypergear hyflowed turbo. I am looking to get back to the power i had before when i had all my parts in. Any help with this will be very helpful :thumbsup:
https://www.sau.com.au/forums/topic/281946-nistune/
  • Replies 46
Put the standard ECU in, get it checked over (defect cleared?) then put the microtech back in?
Do cars in victoria regularly get checked for aftermarket management? Or is it really obvious (hand controller visible?)
Was going to say with the mods you have the nistune would probably be a better option than the microtech. Sell the microtech should cover the costs of getting the nistune installed and tuned.
https://www.sau.com.au/forums/topic/281946-nistune/#findComment-4749288
Had my gtr for 7 or 8 year and have never been checked :happy:
https://www.sau.com.au/forums/topic/281946-nistune/#findComment-4749441
It isnt? I thought it still was in Queensland? lol well thats a load off my mind
They are aligning with the national standard in 18 months but if you get a blue plate now and it has written there that you have an aftermarket ECU, in 18 months when they introduce the standard, you will be ok to keep it. Anyone after the standard is introduced will not be able to have an aftermarket ECU fitted.
There is currently no emmissions testing in QLD so for the time being we are safe. I got this info from DOT and the guy who writes my blue plates.
https://www.sau.com.au/forums/topic/281946-nistune/#findComment-4749582
Its funny how cops can find and EPA you on a high flowed turbo, which they are just identical looks to any other stock turbos. I also had a customer who got defected in Vic over a high flowed GTiR turbo that we worked on. I really believe they have X-ray eyes or some thing to looking through metal housings for bigger wheels.
Nistune is good and cheap. You can get away from most of cops with it. But I don't think Matt have made one for R33 yet. Most people I know is running off a R32 ECU with modified loom.
https://www.sau.com.au/forums/topic/281946-nistune/#findComment-4751777
Nothing available for R33 yet, as far as I was aware it is plug and play with a 20 ecu, its just that you loose the variable valve timing, but I think its only series 1 that might be plug and play as series 2 has the ignitor in the ecu where the Rb20 does not.
https://www.sau.com.au/forums/topic/281946-nistune/#findComment-4752189
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
