I've just gotta set of avs model 6 17x10's to go on the rear of my 32..
turns out i put them on and the inside lip of the rim rubs on my rear hicas powersteering rack (right on the end)
anyone know what i can do to overcome this? spacers, lower control arm change?
everything is stock suspention wise, except a set of JIC coilovers..
anyone know anything about fitting big fat rims, let me know
thanks
I have a set of 18x9.5 on the rear of my car and when I lowered the rear, the camber increased and the inside lip of my rim was rubbing on the lower part of my coil-over suspension.
I solved this by putting on some 8mm spacers and it doesnt rub anymore. However if I want to lower my car any more (and I do), I'll need to get a set of hubcentric spacers (maybe 20mm or so) and that would in effect give the lug nut the same amount of thread to bite onto and push the wheel out of the guard slightly more.
So from my experience, spacers are the answer - if you want anything up yo 10mm you can get them from places like Repco for $30-$45.
i agree get rid of hicus especially if its drift car
u should be running 1 deg or less for drift so you will have to flare gaurds and add small spacer
what offset are they ?
they are +45 and my coilovers make them sit a little lower than the guard anyways. but i am going to roll them
at the moment, i have a 5mm spacer in there and they still rub on my hicas power steering rack..
i have the lockbar in place.. so your saying i can take that whole rack out and it will still be okay? even tho the hicas bit is connected to a control arm or something next to the coilover?
this is what they look like at the moment, with a 5mm spacer in place, still with a bit of room above the tire itself
this is where it is rubbing, on the little pod on the end of the hicas power steering rack
even with the 5mm spacer, it still rubs
can i remove this whole rack entirely?
17 x 10's on a gts-t is a pipe dream under standard rear guards!
pipe dream?
my mate was running 11's on the rear of his R32 gtst four door with slightly rolled guards without a problem
obviously with different offset than i have
Edited by fourdoorlove
hmmmm looks like im pulling the grinder out... might grind a little bit back, not too much of course, cant have the whole rack falling apart, see if i can get a few mm's there and maybe add a slightly bigger spacer, again not too big tho
fingers crossed
Buy rims that fit.
Spacers.. grinding parts etc is as the person above me said, dodgy...
Rims falling off the car isnt a joke :S
See video below:
http://www.youtube.com/watch?v=3oXGbVqfFMc
Edited by br3ndan
thats taking it a bit far i think, that video is a joke if you ask me
ive got plenty of room left on my studs and im only using a 5mm spacer, once i lowered the car back down it didnt rub as the rear camber over compensated for the space between the rim and the hicas, so they fit fine without rubbing
but that is the apsolute maximum size wheel id go with
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
