  • Replies 214
Posted Images
All this talk about Morgan Park is depressing me.
Ryan,,,questions on what fuel system are you running if I may be so rude.
Would I be correct in assuming you are using the factory pump as a lift pump and an 040 as the supply pump. Also what size is that surge tank?.
Cheers
Neil.
Come on Neil and Ryan, even I'm going to Morgan park!
Annual leave approved today... :banana:
Well if one of you guys would be so kind as to ring my boss and tell him he can't have hols then I will be there.
Good luck I couldn't even get him to start them on the tuesday.
shit happens
Neil.
quit like I did..hahahahha
Do what he said...
Oh and it looks like I go to Morgan park one weekend ( I should tell my missus about this hey?) then I go to Thailand the Sunday after, then I go to the ACT the day after I get back from Thailand... Awesome two weeks!!!
  • 1 month later...
Well not much doing on the car but went and purchased some race gear i got some boots and a suit all from Monaco Performance Newcastle, i decided on the GTRacegear range due to its great price and exceptional quality. Below are the links to the pages feel free to PM me if you want any info on them. Bring on the 2011 season so pumped.
Suits
shoes
Monaco Performance
Cheers,
Ryan
lol I thought Ryan was the blonde.
too late for you mate, and looks like they are OK anyway....but be aware the CAMS rules for boots are changing next year (actually they changed 2 years ago but there was an amnesty). You now need to the FIA standard (as yours seem to), not just the SFA or whatever the other standard is called
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
