I might have semi's by then too, kinda had a few grip problems.
I would of thought cold semi's would grip less than RE001's? or have they been heat-f**ked? Mine are 40k km old and have been through many a heat cycle in the hills(hot to touch after a drive), Then again, I have never had semi's(havent driven on the KU36's yet)
What pads/rotors/fluid are you running? I find some pads alot harder than others to recover from a lock-up...
  • Replies 358
Heat-f*cked. They've seen 3 or 4 track days (can't remember) and 1.5 DECA's. They've been melted a couple too many times.
And yes, my brakes are shit and need attention. I'm running SSS brakes front and rear, I haven't changed the master cylinder and brake booster and I've got no ABS. My car stock basically has a drum rear end and tiny calipers up front. It now has bigger calipers (still single piston) up front and discs on the rear. Normally I can deal with them being really touchy but at DECA last weekend they just kept locking up. Obviously the last straw was the sweeper on the Long Wang, locked them up and I was gone.
Pads are Bendix Advance front and Nissan OEM rear, Rotors are DBA slotted front and Nissan OEM rear. I noticed today when I drove the car to the panelbeater that the fluid has boiled over. I've obviously cooked it.
So on my to do list is fixing it cosmetically and mechanically (which is what is happening now), and them paying some attention to my brakes and tyres. Should be there for DECA in November, Long Wang will make me a little nervous though.
i didnt see Romans flat spot but he told me about it!! thats when ABS helps!! lol
ima disconnect the ABS next time and see how i go....my semis are re55s but they dont have much tread left so they will be in the bin after November DECA
ha ha yeas ABS does help prevent flat spots, but it cuts in way too much and slows you down. after doing 2 DECAs with ABS i actually like no ABS. The flat spots are mostly coz my tires are shit and only 185s which is smaller than stock.
hopefully I'll have some 17x9s and some federals before November
If I were you guys I would save my money and spend it elsewhere rather than on expensive semi slick tyres hoping that will make you a better driver, fix all your problems and get you faster times.
Semis = faster corner speeds which means lesser margins for error and also = much harder hits when you collide with something.
Most (not all) of the time cheap semis that have gone through a few hard heat cycles, stick worse than street rubber.
Get decent sized street tyres that will last substantially longer than semis, and save on regular fitting and balances, and spend money on the basics; good pads, good fluid, coilovers and or swaybars, and suspension links that will give you better turn in and decent camber (castor/tension and camber rods). Those get you faster times and arent consumables like tyres.
But hey, if you wanna run semi slicks and be cool, then thats ok too, just my 3c.
Wise words :(
Sarah those pics came out awesome!!
7th...i would have thought a $50 to each time keeper would have been enough for 1st...damn global financial bs. maybe $100 next time team??
great day as always from the DECA team. there is alot of keyboard heros in this thread...or is it just me?
well mick and the guys will be hearing from me, hrm tyre wall. HH on saturday is going to be a struggle me thinks.
I've had quite good experiences with used semis. Sure if you get them at 30% they're pretty shagged and slippery but it's not uncommon to find 60%+ tyres for a fraction of the cost new and they will have more grip than all but the most expensive streets. At deca you don't really get them hot but for actual track work, used semis will outlast any street tyre. Street tyres get hot and fall to bits.
Nobody is saying semis will make you a better driver. They will make the same driver go faster and unfortunately that's the game we're in!
agree with femno and al on the street vs semi tyres
nothing wrong with doing it in street tyres
plenty of the guys have and do
the last thing you want to do is come to something like deca
with semi's on and have no idea how its going to handle
I think what femno was relaying was semi's are a thing to buy but just not the first. Improving your cars suspension while improving your driving skills and then once you have hit the limits of street tyres you will definitely be ready for semis. What's the point of putting them on to take corners at 180km/h when you can't even control the car? Much better to spin out at low speed and learn then spin out at high speed with semis and potentially damage things :P
but then again you vic people are odd :(
Thats what I thought too... and some pad compounds are a lot easier to recover from lockups than others.
I think what femno was relaying was semi's are a thing to buy but just not the first. Improving your cars suspension while improving your driving skills and then once you have hit the limits of street tyres you will definitely be ready for semis. What's the point of putting them on to take corners at 180km/h when you can't even control the car? Much better to spin out at low speed and learn then spin out at high speed with semis and potentially damage things :)
but then again you vic people are odd :thumbsup:
Well said guys.
I am a believer in semis for track but not deca. they are an advantage if they have life in them but a nightmare when they dont (especially on the skid pan). also, cold semis are worse than cold streets, 1 little lock up on the mini wang or the basketball court say hello to way bigger flat spots and canvas if they are low. i normally run semis simply because they are always on the car but i ran streets this time and it was a good reminder that they can teach you things at a still fast but not too fasta speed.
Tubs, i would be bring 3 sets if i was you :)
Just got back from Nissan Datsun Sports Owners Club Vs. FOrd XR club motorkhana and would like to share some ideas which was used in their format.
Their skidpan runs are based on official cams motorkhana circuits
http://cams.com.au/en/Sport/Disciplines/Au...sts%202002.ashx
They split the skidpan in 2, and had 2 seperate skidpan courses on each side (Instead of sauvic having one large skidpan event taking up the whole pan)
The Cams circuits (for example "Happy Birthday" and "World Tour") are small but have plenty of turns in order to do a lot of sideways fun or aim for quick timing. It's also good for the low-powered cars as they dont need huge amounts of power to get from one side of the skidpan to the other.
A couple of goods one are "crossover" and "Straight slalom" etc all small in size but are quite difficult and dont require a lot of power to be quick.
Also at the end of the day, they had a knock out challenge which consisted of slalom up and then back down to the finish line (an idea for future knock outs for sauvic?)
So just throwing out some suggestions for future deca's :thumbsup:
Cheers
interesting read.
i was thinking semi's for november but i'm opting out as even my road tyre's were different cold and hot. Might look into some more suspension work even tho i was very happy with the sliding and steering omg where was my wheel alignment last deca ???? (its soooo much better) but iv'e already spent to much money on my car to just have fun in.
also the question was asked how happy we were with the new format and difficulty which is why i responded. i did watch cars ahead of time and did review the map/layout but minutes in advance. I was able to iron out alot of bugs on the weekend, a problem with only drivin the car on track days.
And if roman wins the type X catagory, i think i win the modified Club Q catagory, lmao how many in the class were there ?
lmao glad i got rid of NA, auto, hicas, abs, 15" tyres and now sunroof
    • I have been being VERY quiet about what you're alluding to, as it is something that ticks me off... The number of cars from factory that run coil overs is HUGE! Most of them these days do... The other part that annoys me, is people saying "Well all the incabin adjustable suspension is illegal by blah blah blah"... If that's the case, then why can I buy a car brand new that can do it if, FULL STOP in cabin adjustable suspension is illegal...   Also, I could just chuck some aftermarket shocks in my car, throw the stock springs on, after my blue slip, dump my super low springs back in. Same shock and spring style setup... Hell, they could also be the same colour springs etc.     I'm voting, BlueSlipper didn't want to touch the above car for some reason. Whether it be some sort of bias against the car, the owner, them maybe having previously done dodgy shit and now they're being super careful in case they get slapped in the face by the Gumbyment again... Find a new blueslip place.   And can confirm as you had said, yes there are holy bibles of vehicle heights, and all sorts of other suspension stuff. Heck your run of the mill mechanic, and tyre shop has access to all of that stuff. It's how they do wheel alignments...
    • Funny story Heading to Sydney this morning on the HWY there was some slow traffic, so I gave it the beans and midway through my overtaking "power run" I lost all power It seems that I missed a hose clamp,  and the MAF and filter went WiFi To make this more problematic, the little tool kit that lives in the boot, is sitting in the sun room at Goulburn......LOL Luckily for me I found a bit of steel on the side of the road that could be used like a rusty and bent flat head screw driver to tighten it up enough that it got me into Sydney, it is now all tight like a tiger with the aid of a 8mm socket Note to self: Use my brain and double check stuff, and always keep that little tool kit in the car for when I have a brain fart
    • Oh, and as for everyone with their fuel economy changes, I switch between E10 and 98 in the company car. Even do when I had personal cars that could run on E10. You know what changed my fuel economy in any noticeable way? How I drove, and where I drove. Otherwise, say on full tanks of just back and forth from work only (So same trips, same sort of traffic), couldn't notice a difference that I can correlate to the type of fuel in use. In the current vehicle, that's over 42L of USABLE fuel. While 98 is all "more energy dense", it also has higher knock resistance as it takes more energy to get it to ignite too. The longer hydrocarbons, typically more tightly bound. So running the same ignition map, can also produce less power, if there isn't enough time to get it all burnt through properly, as yep, the flame propagation speed is different from lower octane fuel to higher (Higher has a lower flame propagation, due to the more tightly bound and harder to self ignite funs. This is also typically where, a vehicle that is designed purely to run on 91 (Whether it be E10 or normal 91) usually sees absolutely no real world difference in fuel economy for the normal man, woman, or dog.
    • We've got some servos around me that have 91 with E10, 91 (no E10), 95, and 98. At those stations the change from 91 E10 to 91, is typically around 8c/L.   But lets not get started on the price of fuel in Oz. It's ridiculous. All the service stations around me, bar one, the price of fuel has been over the $2 mark per litre for the cheapest, 98 being around $2.45. That one service station is a CostCo, fuel from it comes from the same refineries, and makes no pitstops, it runs great, including the 98. In fact, I've had no issues on CostCo fuel, but plenty of issues at other stations!. The CostCo fuel, was $1.65 roughly this week for 94 with E10. $1.88 for 98. Servos directly across from it, $2.10 for 91 E10, and $2.48 for 98. The part I had to laugh at? If I drive multiple HOURS away from Brisbane, say out near Nanango, or Kingaroy, or even out to Goondiwindi, the price of their fuel, is the same as what it is at the CostCo... Oh, and that BP servo at Goondiwindi is HUGE and goes through epic turnover of fuel, so it's not sitting there for weeks going to shit. And what blows me away, my mate is one of the people who drives the Fuel Tanker all around QLD, delivering to all those places. At the same company his previous role was doing the "local haul" deliveries... Same truck, same driver, same pickup point it all comes from. So you tell me, how the hell it is 60c/L CHEAPER for fuel, when nearly all else is equal, except they require a B-Double to drive half a day out of Brisbane, and half a day back, every second day, compared to the delivery that can be under 30 minutes drive from the fuel pickup point... Not to mention, go five blocks down the road, and Ampol to Ampol will vary 30c/L... And I've had this conversation with my mate... The way it's priced, is just typical, pure and utter rubbish... He also does runs from Brisbane, to all over QLD, down to Newcastle, Sydney, Nowra, Melbourne, Geelong, and even out to parts of the NT depending on the companies needs. His main stuff is all the longer distance away from home for a few days at a time, then when he's back, he loves to just pickup extra shifts wherever he can in whichever truck, hence all the weird different places.   Oh, as for getting E10 into all the fuels in Australia... It was very quickly highlighted, that we don't have enough biomass available to use to make E10 sustainably like they require, and it would dramatically cut into our, and the worlds food chain supply...   I vote we all just start running on liquid methane gas... Plenty of that just getting tapped off at tips from underground decay... (Note, this is pure just stupid commenting. I could very easily highlight the reasons its not a good idea especially on scale...)
    • Am I correct in assuming that the R35's are getting the classic skyline haircut off the odometer?  Quick search on carsales, there are 33 08 and 09 GTR's for sale, only 2 of them have more then 100,000km's on them (116,075 and 110,000 respectively).  And somehow there are about 25 for sale with around 60,000kms? Looks like the classic skyline haircut to me =/
