HDi has intrest in making FMIC kits for the NM35 Stagea
Prices will be around 600-800 depending on accessories Clamps + tubing etc
It'll be a custom made FMIC kit for the Stag..
I'v offered my car as a test bed for the KIT and after initial design it'll take 3 months for the production version to be available..
Just wondering who is intrested
core will be 600x300x80 give or take on the thickness..
inlet to outlet ill be 820 over length..
tube and fin core
just seeing some intrest as they are making a kit for my car it'll be a good opportunity to get a FMIC kit made up locally and have tech support local too
Edited by [[d a n n y]]
https://www.sau.com.au/forums/topic/283928-nm35-fmic-kit/
lol well sizeing wise we dunno yet
there are many options
but the aim is to make a bolt on FMIC kit that wont intrude the reo bar
The reason for the low height is to keep it under the bar as this is the dead zone for airflow anyway. Any bigger than about 250mm would hit the bar and thermo fan, while the length you can fit perhaps 700mm and really cool the airflow.
I would be willing to replace mine if there was one made, with proper mounts etc.
https://www.sau.com.au/forums/topic/283928-nm35-fmic-kit/#findComment-4775351
This is a cheaper option than getting my friends to make theirs up from scratch!
i'm all for it! go danny :D
just make sure they do bar and plate and i think maybe they're right about the core being huge too. but get your mate to check it out before hand.
https://www.sau.com.au/forums/topic/283928-nm35-fmic-kit/#findComment-4775700
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
