Well here goes, i was driving from home to Albion Park today (15 mins) and noticed that my temp gauge was reading a little higher than usual (just over half), but i thought nothing of it. Then when i was driving to work this afternoon (30 mins) the temp went up to just over 3/4.
I have owned the car for about 4 months and this is the first time this has happened.
The water level is good and overflow bottle was full (max line), theres no oil in the water or water in the oil and theres no visible water leaks, the radiator cap seems to be ok and the water pump is pumping i think.
The car is running a thermo fan and it is working (was in the car when i bought it) but for some reason it was spinning the wrong way (blowing instead of sucking), it has never gotten hot before.
I tried changing the polarity of the fan and it will suck but i don't know why it hasn't overheated before.
Is there any thing that can automatically make the fan spin backwards?
Has anyone experienced this sort of problem before?
Thanks David
https://www.sau.com.au/forums/topic/283941-r33-gtst-overheating/
Thermo fans spin whichever way you wire them. Is your thermo fan cutting in? It should have a relay and in line fuse.
Fuse is supposed to be [from memory and if its a davies craig unit] 60a. I'll check that and get back to you though.
I've had the same issues with a thermo fan, and it was either the relay or the fuse [i had the vehicle for over 10 years].
But have to say they work fine normally.
Yes the fan is cutting in. They were wired up before i got the car and yes its a davies craig. I have checked the wiring as per the davies craig wiring diagram and it's correct. The fuse is a 10A.
Got pics of the setup?
Your running a shroud I presume? 1 big single or 2 twin thermos?
My experience with non-oem thermo's have failed. 1 x 16" failed, 2 x 12" squeezed in also failed. Both were not running shrouds.
It was fine in the cooler weather but as soon as it started to warm up a little the needle began heading north.
A 10a fuse won't take the load you are putting on it, esp. as it cuts in. by rights shouldn't be working at all. Get on their web site and ask, I'm sure it's a 60a [can't find the paperwork, I must have passed it on when I sold the vehicle].
I rang them and they told me [it was like 8 years ago then], there was a phone number at the bootom of the instruction sheet/warranty.
Spinning the wrong way will make your car heat up at lights and in traffic, if your driving down the road at anything over 40km/h it won't matter, the air blowing through your radiator will do more than any fan can manage.
The Davies craig diagram shows that the fuse is a 5A, im running 10A, which is too big anyway. 60A is way too big, if anything goes wrong it will blow up the fan motor or switch before the fuse blows.
Anyway i changed the polarity of the wires and today on the way to work the temp was back to normal.
Thanks for your help guys.
  • 1 month later...
I had the same problem and after spending a few hundred dollars on fan kits i was getting pissed off - found that it was pumping hot air back thru the un-shrouded core, you could feel it coming thru - fitted the shroud over the 16" and its all good now
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
    • Hi, i’m converted my r34 4dr auto to manual but need help with gearbox wiring. There are bunch of wires no idea which one for speedo drive, neutral, reverse can anyone help me. IMG_6860.mov
