  • Replies 716
Posted Images
some movement on the 4wd hr31 (only took a kid on the way to motivate me to finish it)
old greg has machined the engine and will be building it over the next few weeks so then it will be back for final assembly
nice bloke with picks of the whole process and he is good looking
these things are supposedly good but cost a shittonne in machining to fit
hopefully will do skidz
4wd skidz would be mad fun, id like to see wrx or evo have half a chance of chirping 2nd's....
PS congrats Pete & Jenna, didn't even realise there was a little 1 cooking away when i saw you both the other day. All the best :cheers:
pull the engine out tomorrow to see whats wrong
will get a 9 litre sump as the same time as one of the spare motors goes in
race car got new booties
bought these agaes ago
around 6kg a corner ligher than the rotor rims and rubber
reminds me of the old gibo cars
panasport forged single piece.... nice and light weight
how much extra hp the boot mods worth?
Posting for updates, oh hey look there's one now :P
Block getting kero washed
Wondering what Pete's block would look like with a nitto 3.2L crank
Dummy assembling to measure piston to deck height (and check main tunnel clearances)
(all were exactly 0.0015" no ovality)
(perfect only 0.009" to grind off for 0 deck height)
now to wash the block again and paint it while i continue to reset the tappets after having to correct and redo just about everything on that head
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
