Hey guys,
I'd just like to say thanks for the advice given in regards to my questions about the TD06 stuff in the other thread, based on that and a fair few hours searching I decided to purchase a GT3076r instead as it appears it will be cheaper and easier in a number of ways including installation, while still giving the output I desire, or close to.
I just want to check everything is all ok, as my knowledge of this stuff is pretty minuscule compared to others.
It is an external gate, I asked for a .82 housing but apparently that was going to be too laggy, so i got a .63 rear housing instead.
I ordered an anti surge compressor housing, which it came with, just wanted to ask what this component is as i have not seen it in pictures on the net (see below) and I am assuming it is necessary not just an option to put on?
I was told (and from what I have searched) this turbo will be quite responsive, and put out a substantial amount of power.... roughly 270-280rwkw on about 17psi with supporting mods?
Also, I need 4 longer studs for this to suit the 10mm spacer.. anyone know a place? or the part number or dimensions I need to ask for?
And a final question, what size oil feed line do I need and oil feed bolt?
Thanks, and sorry for the multiple questions, just want to make sure I got the "right one".
Adam
https://www.sau.com.au/forums/topic/285067-got-a-3076r-just-a-conclusion/
  • Replies 73
the optional thingy you have just covers up the surge slots. up to you whether you want to use it or not, will work fine either way.
power will depend on the dyno and the car etc but 270-280rwkw sounds about right.
for the longer studs i just got some from metric man, the thread on the manifold side of the stud is different (cant remember what it is) so make sure you pull one out and take it with you
WYTSKY I have tried for ages to get someone to take pics of the fasteners (grub screws) that hold the funnel mouthed insert in the port shrouded compressor housings .
Can you possibly take a picture of the side of the insert so we can see what the profile of it is like . I'm curious if they have holes or dimples that the three grub screws butt up against .
Also if possible a close up of the grub screws by themselves , I gather they're allen or hex head grub screws .
From what the ID tag says it's a HKS spec Garrett GT3037 56T which is the same as a Garrett GT3076R 56T .
They both start out as turbo assembly no 700382-12 but HKS fit that bell mouthed insert and one of their custom turbine housings and call it a 3037 .
So yes , it's the right one . If it came through a Garrett dealer I'm surprised it has the insert and screws .
Cheers A .
How can you tell from the ID tag that its HKS spec? It looks identical to what I remember mine looking like.
Interesting the .63 is considered more responsive than the .82, on mine there was barely a perceptible difference!
I'm guessing the GT3037S-56T on the tag led to that comment.
Mine also has that tag, it's just what Honeywell apply in the factory. Same item as supplied to HKS, so it really is HKS spec too :)
Good choice BTW Adam. What are you going to use for an exhaust manifold?
Regarding studs, they come as a 10 x 1.5 / 10 x 1.25 combination. Don't fall into the trap of using double ended 1.5 thread pitch. Not a good enough pull down on the gasket, and probable poor seal in the longer term.
Edited by Dale FZ1
Yes both are the same thing . The only difference I've ever noticed is that early HKS ones had BSK1 cast into the compressor housing instead of KTT1 . I believe the difference is the angle of the compressor housings outlet , the BSK1 is at a slightly more acute radius away from the volute so maybe a slightly more compact plumbing option . The HKS bling (blue) tagged ones nowdays use the KTT1 housing as well .
What Garrett originally marketed themselves was not a 3037 as in the 37 or GT37 series compressor wheel , the T series compressor was ~ 76mm OD and used the T04S compressor housing .
The most important thing on the tag is the 700382-12 assembly part number , it means the same thing as 3037S-56T .
My lists of HKS apps also show turbo number 700382-11 which uses the same cartridge (meaning the same compressor) and I'm going to assume it means 3037 , no "S" , so std non port shrouded compressor housing . Other lists I have confirm the non "S" variants as having a 70mm inlet boss vs the S types 100mm one .
Cheers A .
Must remember one day to chase up the 48T versions availability , pretty sure they were 700382-5 and cartridge 700177-5 .
Only one type listed and non ported comp housing , shows same 420 PS output as 2835R and 2835 Pro S and gut feeling tells me it's what the GT3071R should have been .
Edited by discopotato03
Adam
I have just purchased a full fitment kit for a gt3076r IW
The spacer plate will only be needed if using a standard cast manifold
Since yoo have a external gate, you have to use an aftermarket manifold. As previously asked, what make manifold have you got?
Have you trail fitted the turbo to it to see if it hits the new manifold? If you need long bolts, the only place I found was GCG. $36 set with nuts.
Thanks for the input guys, makes me feel at ease ;)
I bought it from Japwarehouse in Melbourne, who got it off their offiical Garrett/Honeywell distributer, Dave was really friendly and helpful and it came the next day!
He believed with a .82 that full boost would be on at about 4,000-4,500 and the .63 at about 3,400-3,500, so i wanted better response.
So if i want anti surge I am meant to take this funnel off?
Disco,Pics are bellow, Tell me if u need any more, this wont be on my car for atleast a month...Yes, they are allen key type, and the funnel DOES NOT have any dimples, or holes for them, the bottom of the fasteners just look like they grab the funnel, but there is and edge surrounding it so it can't slip in or out...
Dale, thanks for the help with the studs and pm, just doubling what I said in the pm:
I have been told I do not need a hks manifold for my application and modifying the stock manifold would be fine. What do you guys think? the only concern i have is if the welds crack if they use a different metal to the manifold that reacts and expands differently to heat and then cracks... but if I get an aftermarket manifold it would be low mount.
I was looking at putting a Tial 44mm gate with it, so as not to get boost creep as I believe it would be large enough?
Cheers,
Adam
post-36975-1251263444_thumb.jpg post-36975-1251263616_thumb.jpg post-36975-1251263697_thumb.jpg post-36975-1251263752_thumb.jpg post-36975-1251263807_thumb.jpg post-36975-1251263872_thumb.jpg
Adam
You will have anti-surge regardless of whether or not you fit the funnel. With the funnel on, the surge path comes back out through the circumferencial slot created between the outer edge of the funnel and the inner intake edge of the compressor cover as depicted in the pics in your initial post. The air will then recirculate back into the funnel mouth.
Edited by juggernaut1
Hmm I had a .63a/r turbine housing and wasn't really happy with the amount of exhaust manifold pressure I was getting - not to say it was a big problem but not ideal, especially if you are going to shoot for near 300rwkw. I am running a .82a/r internal gate and am making 1bar by 3500rpm.
Don't modify the factory manifold, in my opinion - you get an uneven feed to the wastegate and it can also cause havoc with the exhaust flow. I would either run a spacer with a wastegate feed off it, or modify the turbine housing with a feed to the internal gate. I reckon the 44mm will be a winner.
The .82 wont be that much laggier. GT35Rs hit full boost at around 4300-4500rpm.
My 3076 is a .82 at hits 25psi at 3800rpm.
If you are only aiming for 270rwkw then the .63 is a good choice.
With the manifold your cheaper option will be the stainless china jobbies. The best ones ive seen are Tune Agent slash GCG type ones.
Then there is ETM or 6BOOST for the custom steam pipe ones. A little more expensive but worth every penny.
To my understanding that funnel is to keep the spool noise down a little and to funnel the direction of incoming air.
LOL, good buy. But 25G will still smash it :P
In power or spool? Would love to see dyno plots of such a setup as I have always been a bit curious. I doubt spool as a mate has a 20G on his RB25 and it spools about the same as mine, and needs a little more boost to make a couple kw less.
dont external gates spool quicker then an internal
Im currently doing the external gate mod to mine now
Kyle from 6boost is modifying the housing so I can run an external gate
my old setup was the .73 internal gate and it was sloppy with the boost
where as im hoping the new .82 external gate will be a bit friendlier with both power and response
Thats pretty good response, and a ton of pressure! but yeh, i'd say for now i'd like to cap psi to about 15-16 max and no more then 270rwkw... I can always change the exhaust housing later.... but given the compression ratio of the n/a motor and the fact it is not forged yet and its my only car... saftey of the motor would appear to be more important.
I would want something decent and low mount if I have to get a manifold and I want to do this right, so yeh HKS, or 6boost or something up there... Lithium's got me a bit worried. :P
LOL, good buy. But 25G will still smash it :D
haha, thanks for the input :D U know I would have gone down that route if I had the time and money to get it hooked up... gl with it though.
My bad, which bit did I worry you with? In terms of wastegate placement I just warned you off one way and recommended two better ones - off the turbine housing is near the best setup you could do, so long as you're not too vain.
The only thing I'd be worried about is .63a/r hot side on an NA motor, you're potentially going to be quite timing limited.
I've got one with a HKS cast low mount, good turbo, bit lazy at 270rwkw though.
They have good potential to for +300, but you need a built motor, head gasket, or WMI to eliminate knock. But I like the headroom, lets you play and progress the power without having to change turbo's too soon. Only change I would have made was to the larger 0.82 exhaust side, the 0.63 may be more responsive, but it is also more restrictive - you loose your headroom.
And Disco, I didn't know you wanted pics of the cover, I've got one sitting on my shed bench, never used it, could have taken pics any time - hell you can borrow it if you want.
sort of on the topic of the thread, but im wondering how on earth do i make the 3076r not as loud when spooling, its giving me the shits and sounds pretty annoying (that sounds only good on a 450rwkw setup not a 280rwkw one haha), its on an rb30 and its whistling its head off at under 2000rpm on normal acceleration when driving in traffic.
    • Any update on this one? did you manage to get it fixed?    i'm having the same issue with my r34 and i believe its to do with the smart entry (keyless) control module but cant be sure without forking out to get a replacement
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
