Hey guys,
Just out of curiosity when do you guys fill your tanks? I know i personally do mine once a week, usually on a Tuesday. This is regardless on how much fuel i have. Whethers its 3/4 tanks left or 1/2 tank etc etc.
Recently ive only been doing 150-200 clicks per week in the sky.. which is leaves me inbetween 1/2 and 3/4 tank. This is because of two reasons. The first it is cheaper during the start of the week and the second being its not good for the fuel pump if the fuel is too low. If i keep topping up from that level, would that mean there may be some old old fuel still kicking around in there. Or does it not really matter when the fresh stuff is all mixed in?
Type of Fuel i use: BP Ultimate Ron 98. Filled mostly at the same petrol station using the same bowser...
Edited by br3ndan
https://www.sau.com.au/forums/topic/286010-filling-up-the-skyline/
Hey bud
It really doesn't matter if you fill up constantly or when the light comes on, the fuel pump is at the bottom of the tank so its naturally a first-in-first-out system. Stale fuel is also a myth, a few of the boys had their fuel pumps and filters taken out and there was no deposits or gunk found in them.
I'd only be a little precautions if you have an aftermarket fuel pump as they don't like it as much when you're running on empty but if you have a stock one its totally fine.
Here's a similar thread to yours with a bit more info
http://www.skylinesaustralia.com/forums/fi...;hl=fill+petrol
Kind regards,
Danny
Hey guys,
Hmmm... That's not that much mileage for that amount of fuel...
Half a tank will get me about 250 km's and 3/4 will get me over 300 km's...
I think the fuel at the bottom of the tank will go first before the fuel at the top just after you finished filling up petrol.
Next time, empty a tank to about 3/4 and the pour some injector cleaner in then fill up the tank to mix up the injector cleaner.
Next service, change your fuel filter and see how you go.
I ran mine out of fuel once, thinking that the fuel light got me the same milage (50km) as the VN lol. If you ever run out, don't bother only putting in 5L, as it won't start, and will lead to compounded frustration :D
I did the fuel filter when I bought mine, I wouldn't anxiously be doing it again in a hurry ha ha ha.
Otherwise when it starts to go under a quarter I generally try to put fuel in it (usually have to drive 35km to a decent servo as the ones here only sell ethanol crap 95 :S)
Notice how i said "leaves me in between 1/2 and 3/4 tank." . This means Ive used only 1/4 tank of fuel. Leaving 3/4's of it left in the tank. Half tank on the dot will see me around 245kms.
Usually when i pump on tuesday's it will only cost me 25ish dollars to fill to the top.
Thanks for your replies guys... ill keep topping it up weekly then =)
Cars never been under 1/4 of a tank. Always BP Ultimate 98 and I always put $50 in and that $50 usually gets me 300k's. No idea what a full tank would get me as I've never used a full tank :)
Anyone else have this problem; after filling up, the needle will not budge from FULL for about 100-150k's then in the next 100k's or so it will go all the way down to 1/4 full?
Ah ok I get you now. Haha!
I take back what I said...
Cars never been under 1/4 of a tank. Always BP Ultimate 98 and I always put $50 in and that $50 usually gets me 300k's. No idea what a full tank would get me as I've never used a full tank :D
Im pretty sure this just has something to do with the way the fuel tank is in the skylines, They all seem to do it to some degree
Pretty sure the tank is tapered so that theres less volume at the top and more down the bottom. But ive never had mine out so not so sure lol
With my 34, whenever I fill it up full, the needle sits above the FULL for about 70km, then it will drop to down to FULL.
But yea, each 1/4 gives me different mileage, first 1/4 can give me more than second 1/4, but it doesn't really bother me, as I just fill up every tues/wed anyway.
I fill up every 2 or 3 days. Normally get 450kms to a tank from full to sitting on the empty line. I've had the fuel light come on a couple of times but never ran out. I should probably get a daily lol :)
Not sure with a R32, but I've noticed with the R33, R34, when the fuel light comes on, there's still about 15L left in the bank :)
Do you know why its bad for aftermarket pumps? I was told the samething by the mechnical who installed the aftermarket pump (BOSCH intank) when my old stock one died, but he didn't explain the reason.
This happened to me the last time I filled up, was too busy with all of the Uni sh*t going on & I forgot to fill up & was driving around with the needle on E & the fuel light on, I noticed while driving around slowly at the car park the fuel pump was making some loud whinning noises from time to time, scared the crap outta me & I pulled into the closest BP I could find & just filled $10 worth of RON 98. The fuel needle went ontop of E & the pump stopped making that whinning noise.
Later that day, went to my usual Caltex & filled up to full using my parent's shopping discount card :D
Later that day, went to my usual Caltex & filled up to full using my parent's shopping discount card :down:
I think I've read it somewhere before, someone said that aftermarket pump won't suck up the last 1/3 of the tank or something :P
Hey bud
Kind regards,
Danny
both those statements are incorrect. the fuel put into the tank will mix with the fuel in the tank already when filling up and then again when you drive along the road as it sloshes around in the tank. also stale fuel is real. go find a car sitting at a wreckers that has been there for a while (like a year or 2) and pull a fuel line off and inspect what comes out. you won't get a car to run on it very well. the higher the octane of the fuel, the faster it goes stale (loses it's octane rating).
I think I've read it somewhere before, someone said that aftermarket pump won't suck up the last 1/3 of the tank or something :woot:
that is usually because it has been mounted incorrectly. when i put an 040 in a mates 33 i made sure it sat nice and low and he didn't have any issues with running it down until the light came on.
the biggest issue with letting the tank run low is that you start to suck up any crap at the bottom of the tank. when there is a lower concentration of the junk (since it all settles on the bottom when the car is stopped). however once you have run the tank down a few times there won't be much crap left in the tank, it will all be in the filter. i opened up the fuel filter from my magna once day and it was full of crap. even just letting the fuel flow out where it normally went it was enough to get your hand covered in debris.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
