i just had my car tuned today and i was a little disappointed with its power figure
it has:
Unopened RB26
Power FC
RB20 AFM x2
Garrett 2860-5 x2
100mm front mount
adj cam sprockets (both)
bosch 044
sard 700cc inj
nismo fpr
CES dump pipes + 3' exhaust
Greddy Profec b spec 2
and it made 375rwhp at 16psi (about 280rwkw)
the tuner said the profec control unit shat itself, hence the single boost level, even tho it is brand new? WTF?
shouldn't these turbos put me around 325-375rwkw (433-500rwhp)???
i'm suspecting that the weakest link is the Afm's, but they should be able to handle more power than that
because i suspect that higher boost alone won't get me to my target power.
can someone offer some opinions on the matter?
other wise the only
https://www.sau.com.au/forums/topic/286087-rb26-2860-5-power-figure/
he mentioned that this power figure was exactly what he was expecting.
was tuned at brisbane tuning and turbo, and he said after the first hundred GTR's he's tuned, it took the guess work out of the cam gears.
the exhaust is quiet, so that could be an insight.
reading thru the RB26 guide, there are a few cars around this power level with the same turbo's, boost, etc, but this level just doesn't sit well with me
cheers!
anyone else have any ideas?
so much was changed on the car at once
it could be anything
check the basics
ask the mechanic
ask another mechanic
check the dyno chart
check basic engine health and setup - base timing, basic sensors, base compression, base boost check etc
Just curious why you're using that Nismo FPR with the sard 700s, the injectors should be able to support 400kw no problem?
As for power loss, very strange, maybe the timing belt just jumped a tooth.. and what position was/is the CAS set to (the CAS thing shouldnt be an issue if the tuner was familiar with skylines)?
Seem's normal for the boost, slap it on another dyno and you might jump up on the figures. Also, what sort of tune has he done. If it's a stock 26 which is 15 years old that might have to be considered. What the other dudes mentioned might provide some better insight. If it drives well and feels better you should be sweet.
Edited by monga
could be a very tired motor?
i got 214 rwkw out of my RB26 with -5's and running 14psi on stock (ECU, Fuel pump and injectors) with only a full exhaust and pods.
then i had the motor rebuild and now am getting 250rwkw @ 13psi with the same bolt on's, just have had forged pistons put in, full race bearings, R33 crank, head has been recond, block bored, honed and hot washed.
so really it just came down to the fact that the car needed a little bit of a freshen up after 20 years
Brezza
Hey dude, I've got a 1993 R32 that i get tuned at John's, been going to him for a bit now and i think he's always been a straight up guy. He has done a lot of RB's, including his own 240Z conversion putting out 530rwhp with some custom turbos that i've also got on mine. I run a very similar setup to you (plus rebuild) but same afm's and pfc, so if you wanted to swap the afm's over to see if that makes a difference let me know. Can also pressure check you're inlet system for leaks (i found a few after upping the boost). i'm in Brissy (coorparoo) 0403 486 876 if you're interested
Andrew
Seems about right for 16psi through stock cams to me. stick some 260 degree cams and 18-20psi through, and add 100 to that number.
Seems about right, i had HKS 2530s and couldnt get any higher boost then 1.2bar (18psi)
Needed cams, bought tomei 260/260 and made a lot more power and no more boosting problems.. However, im not using RB20 afms, using z32s.
Cheers,
Gordon
You can add 100rwkw on stock cams as well and to make 380rwkw no drama's. Not required.
U'd need at least 22psi and a very aggressive tune to get that on stock cams IMO. Much better to have cams matched to the turbos rather than tryin to push the envelope of one and not the other.
well i'm going to powercruise next weekend, so i'll check it out on their dyno (but is usually really hot there)
i'm looking at a open exhaust for the event and i'll try to turn up the boost a little. hopefully that should give me an idea.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
